Installation & Licensing
smallwoodnh
2258 Views, 4 Replies
Birthdate problem
while registing for a student version i accedentally clicked 2013 instead of 1993 and now it has locked me from changing it, what do i do?
4 REPLIES 4
TravisNave
in reply to: smallwoodnh
Wait 20 years.
Smiley Very Happy
An Autodesk representative can probably help you out on this.
Autodesk Forums:
philip.s
Hi Nicholas,
This is by design as the minimum age for the Education Community is 13. I believe the lock lasts around 15 minutes, and as an alternative to waiting you should be able to proceed by utilizing a different browser.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
nicholasmark16
in reply to: philip.s
I'm having the same problem. I had an existing account somehow, and it has the wrong birth date set in.
@nicholasmark16
Welcome to the Autodesk User's Community..
Is the wrong birth date impacting you and or the ability to access your Autodesk Account?   If not don't worry about it unless you are under 13..  Smiley Very Happy
Mark Lancaster
Administrator Productivity
