• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    rick
    Best export of Autodesk Architecture 2011 3D model into 3D max?
    88 Views, 3 Replies
    03-13-2013 04:19 AM
    We recently installed a network verion of Building Design Suite (BDS). We previously had 4 standalone seats of Infrastructure Design Suite (IDS). When the network seat of BDS is in use we can't access 3dmax or navisworks although we have sufficient licenses under our standalone IDS. We have been trading e-mails with a subscription tech and now after who knows how many e-mails they are saying we need to uninstall and reinstall IDS. So it appears BDS disabled a properly licensed version of IDS and the burden is on us to reinstall IDS. I would also guess that any time we upgrade BDS we will need to reinstall both. There has to be a better answer than allowing program B to disable program A. They are separate properly licensed programs (at least that's what the many high priced checks for purchases and subscription indicate). Any better ideas than currect suggestion? Thank you!
    Please use plain text.
    TravisNave
    Re: Best export of Autodesk Architecture 2011 3D model into 3D max?
    03-13-2013 07:45 AM in reply to: rick
    Mixing network and stand-alone can be hairy, especially when there is product cross-over.  When installing the other suite, you might check to make sure you are not reinstalling the same software overlap.  And even afterwards, you might have to do the registry switch from network to stand-alone.  That *might* work but I am only speculating.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    rick
    03-13-2013 08:02 AM in reply to: TravisNave
    I appreciate the response. I did try the registry switch from network to standalone and it didn't work. Thanks Richard Grady, P.E. Grady Consulting, LLC 71 Evergreen Street, Suite 1 Kingston, MA 02364 Phone 781.585.2300 Fax 781.585.2378 www.GradyConsulting.com
    TravisNave
    03-13-2013 08:32 AM in reply to: rick
    Yeah, it was worth a shot.  Honestly, I have not gotten it to work since the 2010 release myself.  :smileymad:
    Travis Nave
