Installation & Licensing
Best Practice deployments from Building Design Suite Ultimate.
1 REPLY 1
mdhutchinson
325 Views, 1 Reply
Let's say I wish to install AutoCAD MEP, Revit MEP, Navisworks Manage on the vast majority of computers.
What is recommended best practice?
Under a single network folder... is it best to create a SINGLE deployment that will install all three at once?  < or >
Under a single network folder... is it better to create THREE separate deployments, one for each?
or should these be three separate network folders AND three separate deployments?
1 REPLY 1
emily.xu
in reply to: mdhutchinson
If all your clients will install all of the products you mentioned, then you can create one single deployment which including all the three products,so the clients can finish the installation in one time.But the disadvantage is if something wrong with the deployment, no any product can be installed and you need to recreate the whole deployment.
If the clients maybe just install only one or two products, then I recommend you to create separate deployment in separate network folders, so the clients can choose which one to install. And also,these deployments are individual, if anything wrong with some one, you do not need to recreate all the three deployments, just the problematic one.
Anyway,I do not recommend you create three separate deployements in a single folder, for there maybe some unexpected problems.
Here is the best practices when creating deployment, FYI.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Administrator Productivity
