Installation & Licensing
Batch install - Waiting for install to finish
5 REPLIES 5
SzabuniaT
5971 Views, 5 Replies
I'm trying to install the Autodesk2013 Suite using this batch
@echo off
title Installing Autodesk Suite then logging off....
NET USE \\directory /user:********\****** ****** /persistent:YES
ECHO "Installing Autodesk Suite. This workstation will log off automatically when installation is complete."
START /WAIT /B "" "....\Setup.exe" /qb /I \AutoDesk2013.ini /language en-us
ECHO "Finished"
TIMEOUT /T 10
SHUTDOWN /l /f
EXIT
It initialises the install perfectly fine but it isn't waiting until it's finished, instantly moves on. Does this Setup invoke msiexec or something along those lines so the /WAIT doesn't work? If so, is there any way around it because we need to wait until it's finished to be able to log off the account.
Thanks in advance.
5 REPLIES 5
DannyHubbard
in reply to: SzabuniaT
You should just need to add a /W switch to the Setup to get it to wait for the install to finish.
Something like,
START /WAIT /B "" "....\Setup.exe" /w /qb /I \AutoDesk2013.ini /language en-us
Danny
Danny Hubbard
QA Analyst
SzabuniaT
in reply to: DannyHubbard
That didn't work, from what I gathered it's because the Setup.exe launches a separate installer  Here's a workaround that does, little bit hacky though.
@echo off title Installing Autodesk Suite then logging off....
NET USE \\**** /user:*****\***** ******** /persistent:YES
START /B "" "\AdminImage\Setup.exe" /qb /I \AdminImage\AutoDesk2013.ini /language en-us
TIMEOUT /T 10
SETLOCAL
SET TARGET=Setup.exe @ECHO Started!
:LOOP
ping -5 2 localhost >NUL FOR /F %%T IN ('tasklist.exe /FI "IMAGENAME eq %TARGET%"') DO (   SET FOUND=0   IF "%%~T"=="%TARGET%" SET FOUND=1 )
IF %FOUND%==1 GOTO :LOOP
ECHO "Finished"
TIMEOUT /T 10
SHUTDOWN /l /f
EXIT
DannyHubbard
A few other options would be to try the following.
CALL "" "....\Setup.exe" /w /qb /I \AutoDesk2013.ini /language en-us
Or since it appears you have already created a deployment you could just run the shortcut link for the deployment with something like.
CALL "\\server_name\share_name\deployment_folder\deployment_name.lnk" /w
Danny
Danny Hubbard
QA Analyst
Thanks Danny.  It looks like the CALL is holding the batch file.
Sara
Arlington County Schools
Arlington, VA
@DannyHubbard  You sir are a kind one! Thank you very much for the gift of "/w"
Administrator Productivity
