• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    Chris
    Basic info for Install of 2013
    172 Views, 2 Replies
    04-12-2012 10:06 PM
    Can you tell me where to find the basic requirements BEFORE downloading the new release?
    What minimum spec PC is required, do I uninstall 2012 first using the quick uninstall for Autodesk products?
    How long does it take for product suite ultiimate?
    best rgds CHRIS
    CjWard
    Please use plain text.
    TravisNave
    Re: Basic info for Install of 2013
    04-15-2012 03:15 PM in reply to: Chris
    Installing the entire suite can be as little as 45 minutes to as much as 4 hours depending on the speed of your machine and the options you choose.  You do not need to uninstall the 2012 suite first as they will live side-by-side just fine.  You may need to however on the content center and material library databases, however.
    http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=16491127
    System requirements are different for each program in the suite.  As long as you meet the requirements for the most intensive programs, i.e. Inventor, Maya, then you should be fine.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    Chris
    04-16-2012 12:01 AM in reply to: TravisNave
    Thank you Guru, I'll give it a try on one machine, I normally have my CAD dealer install for me, but all UK CAD dealers have doubled their prices. Best rgds CHRIS
    CjWard
