Installation & Licensing
corestudio
Message 1 of 10 (3,748 Views)
Accepted Solution
Backburner Mac 2011
3748 Views, 9 Replies
07-14-2010 03:31 PM
I'm trying to install backburner 2011 Mac. But I'm completely stymied. Is there an actual guide that reflects reality? The first steps:
To install Backburner on a Mac workstation: 1    Insert the Smoke for Mac OS X application DVD and double-click the DVD icon that appears on the
desktop. If installing from a downloaded disk image (.dmg) file, double-click that file first.
2    Make use of the installation wizard options to install the Backburner Manager and/or Backburner Server, per your configuration requirements.
3    Once completed, verify that the needed components have been properly installed and started. Go to Applications / Autodesk in Finder, and open the Autodesk Systems Monitor application.
don't reflect what actually happens. There is no Autodes Systems Monitor application. I can't go any further.
I'm using Maya 2011. Thanks
Product Support
hashim.mundol
Message 2 of 10 (3,741 Views)
Re: Backburner Mac 2011
07-15-2010 12:39 AM in reply to: corestudio
I assume you are refering to the following install guide
http://images.autodesk.com/adsk/files/backburner20100.2_install_guide.pdf
This Part of Document is only for Smoke
"NOTE
The following procedure applies to Smoke for Mac OS X only. For Maya, use the application DVD to install all needed Backburner components. "
For maya installation you should find backburner installed under
/usr/discreet/backburner
probably the second part of the document(page 77) can help you further.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
corestudio
Message 3 of 10 (3,732 Views)
07-15-2010 10:05 AM in reply to: hashim.mundol
OK, thanks Hashim. I'll go over the guide once again.
corestudio
Message 4 of 10 (3,731 Views)
07-15-2010 10:12 AM in reply to: corestudio
Hasim-
would you consider it a good strategy to first get Backburner working on a single machine as a test, then deploy for the farm? I'm just not sure about the implications of setting up the Manager and what that would mean to change the setup. Thanks
corestudio
Message 5 of 10 (3,729 Views)
07-15-2010 10:29 AM in reply to: corestudio
Nevermind. I see the docs answer that for Maya, there is no standalone BB option. Off to Setting up a Render Farm I go.
corestudio
Message 6 of 10 (3,721 Views)
07-15-2010 11:35 AM in reply to: hashim.mundol
Hashim-
OK, things are looking up. Somewhat. I can submit Backburner jobs. I can see all the Macs (with maya installed) on the network. However:
Each is listed in the Manager pop up of the Backburner Monitor
Each only has "access" to itself. i.e. I'm not able to create a Server Group containing all the macs.
Another issue is that I've tried to set up a separate machine as a standalone Manager, but the maya installer simply says "failed on exit" for the Backburner component. After install there is no /usr/discreet/ dir. Can I manually install and start the Manager?
Lastly, I want to ultimately be able to render cross-platform. The docs don't seem to cover this. How to deal with file paths, etc?
thanks
Product Support
hashim.mundol
Message 7 of 10 (3,683 Views)
07-19-2010 05:08 AM in reply to: corestudio
From the User Guide > Rendering and Render Setup > Rendering > Network rendering > Maya network rendering >
Network rendering with Backburner:
Install Backburner and Maya in the same folder location on each of your render farm nodes. Therefore, you cannot mix Windows render nodes with Linux render nodes or Windows render nodes with Mac OS X render nodes and so forth..
To use multiple different OS'es set up separate render farms (manager + servers) and submit a sequence of frames to each of the managers.
Hashim Mundol
Autodesk, Inc.
New Member
robstein3
Message 8 of 10 (2,091 Views)
08-25-2011 12:19 PM in reply to: hashim.mundol
"Therefore, you cannot mix Windows render nodes with Linux render nodes or Windows render nodes with Mac OS X render nodes and so forth."
If all your nodes are PC, and your BB Manager is on a PC, can you sumbit a job with "Render / Create Backburner Job" from Maya on OSX?
If not, can you save the file from Maya OSX, and Command Line render from the PC (with Manager) without opening the Maya file in a PC version of MAYA and resaving it?
Product Support
hashim.mundol
Message 9 of 10 (2,086 Views)
08-25-2011 01:13 PM in reply to: robstein3
Since I am not expers in the rendering, not able give you a simple answer
you might get a better answer in this forum
http://area.autodesk.com/
I will check with some experts internally as well..
Hashim Mundol
Autodesk, Inc.
New Member
hack.les
Message 10 of 10 (681 Views)
i im to
01-16-2013 01:15 AM in reply to: corestudio
i cant feger out a way
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
