• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Backburner 2012 on Linux - web monitor not seeing Manager
    635 Views, 3 Replies
    03-26-2012 09:53 AM
    Hello folks,
    I'm setting up a shared Backburner render farm for our Maya students at my school. For ease of support and backup our IT department has asked that I set up the manager and web monitor components on a virtualized Linux machine. The render nodes are three dedicated Macs and several OSX lab stations whose availablilty will be contolled by a render admin.
    Maya 2012 SP2 and the latest backburner components (2012.1.1_1575) installed on the render nodes and the equivalent Backburner components on the linux manager vm - which has CentOS 6.2 as the OS.
    The linux Backburner Manager and Web Monitor have been configured on the manager VM and the web service is running. I can log in to the web monitor with an admin account but I don't see the Manager listed anywhere. I confess I had no luck troubleshooting using the output from the backburner.log:
    2012/03/26 11:00:04 ERR Error accepting connection: Bad file descriptor (9).
    2012/03/26 11:00:05 INF Starting Network Manager
    2012/03/26 11:00:05 INF <AdapterInfo>
    2012/03/26 11:00:05 INF     <Name>Command Line Tool</Name>
    2012/03/26 11:00:05 INF     <Version>400</Version>
    2012/03/26 11:00:05 INF     <Description>Command Job Adapter v2012.1.1 with user rights</Description>
    2012/03/26 11:00:05 INF </AdapterInfo>
    2012/03/26 11:00:05 INF     <Version>300</Version>
    2012/03/26 11:00:05 INF     <Description>Command Job Adapter v2012.1.1</Description>
    2012/03/26 11:00:05 INF Loading plugin: Command Job Adapter v2012.1.1 with user rights from Backburner Adapter Plugin
    2012/03/26 11:00:05 INF Loading plugin: Command Job Adapter v2012.1.1 from Backburner Adapter Plugin
    2012/03/26 11:00:05 ERR Unable to connect to 10.10.100.49: Connection refused (111).
    2012/03/26 11:00:06 INF New client 10.10.100.49 added to client list
    2012/03/26 11:00:06 INF Wiretap interface connected to the local manager
    2012/03/26 11:21:39 INF New client 10.10.254.171 added to client list
    I'm not quite sure where to head next. Any advice would certainly be appreciated.
    Many thanks.
    Please use plain text.
    Member
    techmanager
    Re: Backburner 2012 on Linux - web monitor not seeing Manager
    04-20-2012 03:24 PM in reply to: nmendolia
    Hello - I just set up the Backburner Manager and Web monitor on a Linux distro more or less the same as yours (Scientific Linux 6.2) and am experiencing the same problem. I can access the Web monitor from any machine on the network, but there is no manager listed to monitor. Did you end up resolving your problem? If so I would be interested in hearing from you. As best I can tell the Web Monitor does not require any additional configuration. I can start Server on the workstations and point it at the Manager...and those connect just fine. I just can't monitor the Manager from the Web interface (which was the whole point of this exercise).
    New Member
    04-23-2012 06:48 PM in reply to: techmanager
    In fact I did resolve this issue. A very helpful support chap at Autodesk pointed me in the right direction. It turns out RHEL and CentOS distributions make use of a feature called SELinux - Security Enhanced Linux that evidently works in tandem with the firewall settings established through iptables. I'm new to RHEL so this was news to me. Here's a good overview of how SELinux works.
    By default SELinux locks down traffic over http. For our purposes it was overkill so I just turned it off by editing the /etc/selinux/config file as follows:
    vi /etc/selinux/config
    changed the line
    SELINUX=enforcing
    to
    SELINUX=disabled
    I saved the file and restarted the server, but to test it you could just switch SELinux off for the current session with:
      echo 0 >/selinux/enforce
    then restart Apache and the Backburner service.
    Finally, I set a rule to open port 80 through the server firewall and the Backburner manager showed up in the Web Monitor right away.
    I hope this helps. Again, thanks to Nelson Cruz at Autodesk tech support for patiently working it out.
    Member
    techmanager
    05-01-2012 12:42 PM in reply to: nmendolia
    I actually came to that same solution after looking at some logs and dwelling on the topic for a few minutes. So now I have Web Monitor working!
