Simon,
If you are running a software locked version of MDT5 please ensure you apply
the latest RTS:-
http://support.autodesk.com/getDoc.asp?id=DL402225
We had an issue with early RTS's killing peer to peer connections.
Simon Gillis
Autodesk Professional Services
"Simon71" wrote in message
news:897B400320A16221BB1BF6AFCB10F8AF@in.WebX.maYIadrTaRb...
> Systems: Windows 2000 Pro + SP3 + MDT5
> I share some folders on this system, that can be accessed regularly from
> other PCs on my peer-to-peer network, at full speed.
> At least until I start MDT5 on this system.
> After I started it, the network on this machine hangs! All other PCs can
> barely access to network resources on this machine, and even if they can
> reach the network resource, they can't copy no file!
> This happens only AFTER I started MDT5 and even if I shutdown it. The only
> way to fix the problem is to reboot the entire Win2K-MDT5 system.
> (p.s. all other machines on the net have no problem, browse themselves
> regularly and can browse the MDT5 machine ok, until I start MDT5, and even
> when I started it, the TCP protocol seems ok, only the "network sharing"
> seems to be affected....)
> Help me please!
