• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Expert Elite*
    LisaDrago
    BDS Ultimate AutoCAD MEP 2013 instillation failure
    153 Views, 4 Replies
    01-15-2013 04:25 PM
    Hello - I have been trying to install AutoCAD MEP 2013 and cannot get it to work - I will post the log file.
    Any ideas???
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    Please use plain text.
    Product Support
    emily.xu
    Re: BDS Ultimate AutoCAD MEP 2013 instillation failure
    01-16-2013 09:27 PM in reply to: LisaDrago
    Try this solution.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Emily Xu
    AutodeskCare | Product Support
    Autodesk, Inc.
    *Expert Elite*
    TravisNave
    01-17-2013 08:13 AM in reply to: LisaDrago
    I have noticed a lot of the AutoCAD vertical failures have to do with the fact that other flavors of AutoCAD are already installed.  Since many of them apparently install into the native \AutoCAD 2013\ folder, subsequent installs fail.  I noticed this when trying to install Mechanical 2013 when AutoCAD 2013 was already installed.  It failed.  When I removed AutoCAD 2013, it installed.  So see if you have any other verticals installed first and go from there.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    *Expert Elite*
    LisaDrago
    01-17-2013 01:04 PM in reply to: TravisNave
    I tried unloading the service pack and it still did not install - I can try removing autocad 2013 to see if it will work...
    but then I am thinking 2014 should be out shortly - is it worth the trouble?
    LD
    *Expert Elite*
    TravisNave
    01-17-2013 02:04 PM in reply to: LisaDrago
    I hear ya.  I literally just had a user rename their existing AutoCAD 2013 folder to something else and it installed.  Might be worth a shot.
    Travis Nave
