Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
BDS Ultimate AutoCAD MEP 2013 instillati on failure
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello - I have been trying to install AutoCAD MEP 2013 and cannot get it to work - I will post the log file.
Any ideas???
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: lisa@kalblue.com
Re: BDS Ultimate AutoCAD MEP 2013 instillati on failure
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try this solution.
__________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
AutodeskCare | Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have noticed a lot of the AutoCAD vertical failures have to do with the fact that other flavors of AutoCAD are already installed. Since many of them apparently install into the native \AutoCAD 2013\ folder, subsequent installs fail. I noticed this when trying to install Mechanical 2013 when AutoCAD 2013 was already installed. It failed. When I removed AutoCAD 2013, it installed. So see if you have any other verticals installed first and go from there.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: BDS Ultimate AutoCAD MEP 2013 instillati on failure
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried unloading the service pack and it still did not install - I can try removing autocad 2013 to see if it will work...
but then I am thinking 2014 should be out shortly - is it worth the trouble?
LD
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I hear ya. I literally just had a user rename their existing AutoCAD 2013 folder to something else and it installed. Might be worth a shot.
