Installation & Licensing
BDS Premium deploy necessary?
5 REPLIES 5
Jroper
529 Views, 5 Replies
If I have created a deployment for Building Design Suite Ultimate, would there be any need for creating a Building Design Suite Premium deployment?  The only difference between Premium and Ultimate would be Navisworks Manage, correct?
5 REPLIES 5
DarrenP
in reply to: Jroper
ultimate also has Inventor & quantity takeoff
is this a network license or standalone licenses?
DarrenP
Jroper
in reply to: Jroper
Network.
DarrenP
in reply to: Jroper
your supposed to put ultimate on all machines
and the cascading sequence determines the correct license to pull
DarrenP
Jroper
in reply to: Jroper
I guess my question's purpose was trying understand if there is anything special about the products contained in a Suite deployment vs. any other deploy.
Example:
In my BDS Ultimate deployment there is the 3ds Max product.  But I also have a separate deployment created for just loading 3ds Max.  So a user could get the 3ds Max product installed from the Suite or from the non-Suite deployment.  If I understand cascading correctly, when 3ds Max is launched, the license server will check for the cheapest license with the 3ds Max feature code and will continue on up to more expensive licenses until a license with that feature code is found.  Correct?
DarrenP
in reply to: Jroper
yes you are correct
DarrenP
Administrator Productivity
