I've found the Navisworks exporter pack for Navisworks 2012, but we are working with Naviswork Manage 2010 so I'm looking for NWC file exporter Pack for Naviswork 2010 but I can't find it on the autodesk website. Is it still available ? We want to export Revit files to Navisworks
Solved by lee.mullin. Go to Solution.
for 2010 you have to go to the subscription website and download it
DarrenP
I have repied to your other post too.
It is no longer available but if you have the 2010 installation disc you will be able to create a custom install of just the exporters.
Alternatively you may want to use the 2012 exporters, open the NWC in Navisworks and save back as an earlier version.
Please let me know how you get on
I've already installed the 2012 Navisworks exporters, but I can't open the export file with Navisworks Manage 2010. So it's not possible to save them back to an earlier version.
We already tried to install the exporters 2010 in the windows add/remove program dialog box. By clicking change/remove Navisworks 2010 but there is no option to install the exporter, only the language pack and three other options. All of them are already installed.
In Add/Remove programs there should be a seperate line item Autodesk Navisworks 2010 32 or 64 bit Exporter Plug Ins.
Sorry I assumed you had a copy of Manage or Simulate 2012 installed, my mistake.
This should be Add/Remove Programs itself, before you get to this page.
As mentioned earlier, the best way to get these would be the 2010 installation disc and create a custom install just installing the exporter plug-ins. Do you still have this?
