2014/1/27:23:56:57 user USER-PC === Setup started on USER-PC by user ===
2014/1/27:23:56:57 user USER-PC Path_Length: 149
2014/1/27:23:56:57 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/27:23:56:57 user USER-PC Launch
2014/1/27:23:56:57 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/27:23:56:57 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI6374.tmp
2014/1/27:23:57:09 user USER-PC === Setup ended ===
2014/1/27:23:56:58 user USER-PC === Setup started on USER-PC by user ===
2014/1/27:23:56:58 user USER-PC Path_Length: 149
2014/1/27:23:56:58 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI6374.tmp
2014/1/27:23:56:58 user USER-PC Launch
2014/1/27:23:57:06 user USER-PC Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-...
2014/1/27:23:57:06 user USER-PC Connection has expired. Please reconnect to site.2014/1/27:23:57:10 user USER-PC === Setup ended ===
2014/1/27:23:57:28 user USER-PC === Setup started on USER-PC by user ===
2014/1/27:23:57:28 user USER-PC Path_Length: 149
2014/1/27:23:57:28 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/27:23:57:28 user USER-PC Launch
2014/1/27:23:57:28 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/27:23:57:28 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AID604.tmp
2014/1/27:23:57:54 user USER-PC === Setup ended ===
2014/1/27:23:57:32 user USER-PC === Setup started on USER-PC by user ===
2014/1/27:23:57:32 user USER-PC Path_Length: 149
2014/1/27:23:57:32 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AID604.tmp
2014/1/27:23:57:32 user USER-PC Launch
2014/1/27:23:57:34 user USER-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/27:23:57:53 user USER-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/27:23:57:53 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AID604.tmp\Setup\RevitSetup.dll
2014/1/27:23:57:53 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/27:23:57:53 user USER-PC PageOpen LaunchDialog
2014/1/28:00:00:38 user USER-PC PageOpen LicenseDialog
2014/1/28:00:01:08 user USER-PC PageOpen ProductInfoDialog
2014/1/28:00:01:08 user USER-PC PageOpen ProductSelectionDialog2
2014/1/28:00:01:16 user USER-PC PageOpen FullProgressDialog
2014/1/28:00:01:17 user USER-PC Download Play VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/28:00:01:19 user USER-PC Download Complete VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/28:00:01:19 user USER-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/1/28:00:01:23 user USER-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/1/28:00:01:23 user USER-PC Download Play VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/28:00:01:25 user USER-PC Download Complete VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/28:00:01:25 user USER-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/1/28:00:01:28 user USER-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/1/28:00:01:29 user USER-PC Download Play KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:29 user USER-PC Download Complete KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:29 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:01:36 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/1/28:00:01:37 user USER-PC Download Play KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:40 user USER-PC Download Complete KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:40 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:01:51 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/1/28:00:01:52 user USER-PC Download Play KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:53 user USER-PC Download Complete KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:53 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:02:02 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/1/28:00:02:03 user USER-PC Download Play KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:03 user USER-PC Download Complete KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:03 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:02:12 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/1/28:00:02:12 user USER-PC Download Play KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:13 user USER-PC Download Complete KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:13 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:02:18 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/1/28:00:02:19 user USER-PC Download Play KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:22 user USER-PC Download Complete KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:22 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:02:35 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/1/28:00:02:35 user USER-PC Download Play KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:36 user USER-PC Download Complete KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:36 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:02:45 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/1/28:00:02:45 user USER-PC Download Play KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:46 user USER-PC Download Complete KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:46 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:02:53 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/1/28:00:02:54 user USER-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/28:00:02:56 user USER-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/28:00:02:56 user USER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/28:00:03:25 user USER-PC Install DirectX® Runtime Succeeded
2014/1/28:00:03:26 user USER-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:07:09 user USER-PC Download Error RVT2014 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:07:39 user USER-PC Download Error RVT2014 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:10:55 user USER-PC Download Complete RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:11:06 user USER-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AID604.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="Z:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:18:50 user USER-PC Install Autodesk® Revit® 2014 Succeeded
2014/1/28:00:18:50 user USER-PC Download Play RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:18:57 user USER-PC Download Aborted RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:18:57 user USER-PC Install Autodesk® Revit® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/1/28:00:23:22 user USER-PC Rollback Autodesk® Revit® 2014 Succeeded
2014/1/28:00:23:22 user USER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/28:00:23:28 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/1/28:00:23:32 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/1/28:00:23:36 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/1/28:00:23:39 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/1/28:00:23:43 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/1/28:00:23:48 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/1/28:00:23:52 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/1/28:00:23:55 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/1/28:00:23:56 user USER-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/1/28:00:23:56 user USER-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/1/28:00:23:56 user USER-PC PageOpen InstallCompleteDialog
2014/1/28:00:24:20 user USER-PC === Setup ended ===
2014/1/28:00:31:28 user USER-PC === Setup started on USER-PC by user ===
2014/1/28:00:31:28 user USER-PC Path_Length: 149
2014/1/28:00:31:28 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/28:00:31:28 user USER-PC Launch
2014/1/28:00:31:28 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/28:00:31:28 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp
2014/1/28:00:31:37 user USER-PC === Setup ended ===
2014/1/28:00:31:29 user USER-PC === Setup started on USER-PC by user ===
2014/1/28:00:31:29 user USER-PC Path_Length: 149
2014/1/28:00:31:29 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp
2014/1/28:00:31:29 user USER-PC Launch
2014/1/28:00:31:36 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/28:00:31:36 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp\Setup\RevitSetup.dll
2014/1/28:00:31:36 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/28:00:31:36 user USER-PC PageOpen LaunchDialog
2014/1/28:00:34:19 user USER-PC PageOpen LicenseDialog
2014/1/28:00:34:29 user USER-PC PageOpen ProductInfoDialog
2014/1/28:00:34:29 user USER-PC PageOpen ProductSelectionDialog2
2014/1/28:00:34:48 user USER-PC PageOpen FullProgressDialog
2014/1/28:00:34:49 user USER-PC Download Skipped KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:34:49 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:34:52 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/1/28:00:34:52 user USER-PC Download Skipped KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:34:52 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:34:59 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/1/28:00:35:00 user USER-PC Download Skipped KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:00 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:35:06 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/1/28:00:35:06 user USER-PC Download Skipped KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:06 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:35:12 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/1/28:00:35:12 user USER-PC Download Skipped KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:12 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:35:15 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/1/28:00:35:16 user USER-PC Download Skipped KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:16 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:35:24 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/1/28:00:35:24 user USER-PC Download Skipped KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:24 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:35:30 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/1/28:00:35:30 user USER-PC Download Skipped KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:30 user USER-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:35:36 user USER-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/1/28:00:35:36 user USER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/28:00:35:36 user USER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/28:00:36:09 user USER-PC Install DirectX® Runtime Succeeded
2014/1/28:00:36:09 user USER-PC Download Skipped RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:36:10 user USER-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="Z:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:44:37 user USER-PC Install Autodesk® Revit® 2014 Succeeded
2014/1/28:00:44:38 user USER-PC Download Play RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:44:46 user USER-PC Download Complete RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:44:47 user USER-PC Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp\_la2EC5.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="Z:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:44:56 user USER-PC Install Autodesk® Revit® 2014 Language Pack Succeeded
2014/1/28:00:44:56 user USER-PC Installing Autodesk Workflows 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:45:02 user USER-PC Install Autodesk Workflows 2014 Succeeded
2014/1/28:00:45:03 user USER-PC Download Play CMILL2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILL201...
2014/1/28:00:46:37 user USER-PC Download Complete CMILL2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILL201...
2014/1/28:00:46:37 user USER-PC Installing Autodesk Material Library 2014 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/28:00:46:56 user USER-PC Install Autodesk Material Library 2014 - Low Image Library Succeeded
2014/1/28:00:46:57 user USER-PC Download Play CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/1/28:00:49:32 user USER-PC Download Error CMILM2014 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/1/28:00:54:59 user USER-PC Download Aborted CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/1/28:00:54:59 user USER-PC Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2014/1/28:00:55:17 user USER-PC Rollback Autodesk Material Library 2014 - Low Image Library Succeeded
2014/1/28:00:55:20 user USER-PC Rollback Autodesk Workflows 2014 Succeeded
2014/1/28:00:55:31 user USER-PC Rollback Autodesk® Revit® 2014 Language Pack Succeeded
2014/1/28:01:00:02 user USER-PC Rollback Autodesk® Revit® 2014 Succeeded
2014/1/28:01:00:02 user USER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/28:01:00:09 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/1/28:01:00:13 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/1/28:01:00:17 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/1/28:01:00:21 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/1/28:01:00:25 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/1/28:01:00:30 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/1/28:01:00:35 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/1/28:01:00:39 user USER-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/1/28:01:00:39 user USER-PC PageOpen InstallCompleteDialog
2014/1/28:01:00:57 user USER-PC === Setup ended ===
2014/2/3:23:13:28 user USER-PC === Setup started on USER-PC by user ===
2014/2/3:23:13:28 user USER-PC Path_Length: 149
2014/2/3:23:13:28 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/3:23:13:28 user USER-PC Launch
2014/2/3:23:13:28 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/3:23:13:28 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIB418.tmp
2014/2/3:23:13:34 user USER-PC === Setup ended ===
2014/2/3:23:13:29 user USER-PC === Setup started on USER-PC by user ===
2014/2/3:23:13:29 user USER-PC Path_Length: 149
2014/2/3:23:13:29 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIB418.tmp
2014/2/3:23:13:29 user USER-PC Launch
2014/2/3:23:13:32 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/3:23:13:33 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIB418.tmp\Setup\RevitSetup.dll
2014/2/3:23:13:33 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/3:23:13:34 user USER-PC PageOpen LaunchDialog
2014/2/4:00:42:59 user USER-PC === Setup started on USER-PC by user ===
2014/2/4:00:42:59 user USER-PC Path_Length: 149
2014/2/4:00:42:59 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/4:00:42:59 user USER-PC Launch
2014/2/4:00:42:59 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/4:00:42:59 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIA50C.tmp
2014/2/4:00:43:27 user USER-PC === Setup ended ===
2014/2/4:00:43:01 user USER-PC === Setup started on USER-PC by user ===
2014/2/4:00:43:01 user USER-PC Path_Length: 149
2014/2/4:00:43:01 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIA50C.tmp
2014/2/4:00:43:01 user USER-PC Launch
2014/2/4:00:43:03 user USER-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/4:00:43:25 user USER-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/4:00:43:25 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIA50C.tmp\Setup\RevitSetup.dll
2014/2/4:00:43:25 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/4:00:43:27 user USER-PC PageOpen LaunchDialog
2014/2/4:00:43:49 user USER-PC PageOpen LicenseDialog
2014/2/4:00:44:46 user USER-PC PageOpen ProductInfoDialog
2014/2/4:00:48:23 user USER-PC PageOpen ProductSelectionDialog2
2014/2/4:00:49:05 user USER-PC === Setup ended ===
2014/2/4:00:54:38 user USER-PC === Setup started on USER-PC by user ===
2014/2/4:00:54:38 user USER-PC Path_Length: 149
2014/2/4:00:54:38 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/4:00:54:38 user USER-PC Launch
2014/2/4:00:54:38 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/4:00:54:38 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI5374.tmp
2014/2/4:00:54:43 user USER-PC === Setup ended ===
2014/2/4:00:54:39 user USER-PC === Setup started on USER-PC by user ===
2014/2/4:00:54:39 user USER-PC Path_Length: 149
2014/2/4:00:54:39 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI5374.tmp
2014/2/4:00:54:39 user USER-PC Launch
2014/2/4:00:54:43 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/4:00:54:43 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI5374.tmp\Setup\RevitSetup.dll
2014/2/4:00:54:43 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/4:00:54:43 user USER-PC PageOpen LaunchDialog
2014/2/7:18:49:19 user USER-PC === Setup started on USER-PC by user ===
2014/2/7:18:49:19 user USER-PC Path_Length: 149
2014/2/7:18:49:19 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/7:18:49:19 user USER-PC Launch
2014/2/7:18:49:19 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/7:18:49:19 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp
2014/2/7:18:49:24 user USER-PC === Setup ended ===
2014/2/7:18:49:21 user USER-PC === Setup started on USER-PC by user ===
2014/2/7:18:49:21 user USER-PC Path_Length: 149
2014/2/7:18:49:21 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp
2014/2/7:18:49:21 user USER-PC Launch
2014/2/7:18:49:23 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/7:18:49:23 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp\Setup\RevitSetup.dll
2014/2/7:18:49:23 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/7:18:49:23 user USER-PC PageOpen LaunchDialog
2014/2/7:18:49:35 user USER-PC PageOpen LicenseDialog
2014/2/7:18:49:38 user USER-PC PageOpen ProductSelectionDialog2
2014/2/7:18:49:45 user USER-PC PageOpen LicenseDialog
2014/2/7:18:49:46 user USER-PC PageOpen LaunchDialog
2014/2/7:18:49:52 user USER-PC PageOpen LicenseDialog
2014/2/7:18:49:56 user USER-PC PageOpen ProductInfoDialog
2014/2/7:18:51:12 user USER-PC PageOpen ProductSelectionDialog2
2014/2/7:18:51:57 user USER-PC PageOpen FullProgressDialog
2014/2/7:18:51:57 user USER-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/7:18:52:01 user USER-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/7:18:52:01 user USER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/7:18:52:51 user USER-PC Install DirectX® Runtime Succeeded
2014/2/7:18:52:51 user USER-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/7:18:59:18 user USER-PC Download Complete RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/7:18:59:23 user USER-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:19:07:37 user USER-PC Install Autodesk® Revit® 2014 Succeeded
2014/2/7:19:07:38 user USER-PC Download Play RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/7:19:07:56 user USER-PC Download Complete RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/7:19:07:57 user USER-PC Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp\_la9A0.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:19:08:03 user USER-PC Install Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/7:19:08:04 user USER-PC Installing Autodesk Workflows 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:19:08:18 user USER-PC Install Autodesk Workflows 2014 Succeeded
2014/2/7:19:08:19 user USER-PC Download Play CMILL2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/7:19:10:07 user USER-PC Download Complete CMILL2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/7:19:10:07 user USER-PC Installing Autodesk Material Library 2014 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:19:10:41 user USER-PC Install Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/7:19:10:42 user USER-PC Download Play CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/7:19:17:14 user USER-PC Download Aborted CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/7:19:17:14 user USER-PC Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2014/2/7:19:17:40 user USER-PC Rollback Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/7:19:17:42 user USER-PC Rollback Autodesk Workflows 2014 Succeeded
2014/2/7:19:17:57 user USER-PC Rollback Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/7:19:21:49 user USER-PC Rollback Autodesk® Revit® 2014 Succeeded
2014/2/7:19:21:49 user USER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/7:19:21:50 user USER-PC PageOpen InstallCompleteDialog
2014/2/7:19:35:55 user USER-PC === Setup ended ===
2014/2/7:19:41:12 user USER-PC === Setup started on USER-PC by user ===
2014/2/7:19:41:12 user USER-PC Path_Length: 149
2014/2/7:19:41:12 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/7:19:41:12 user USER-PC Launch
2014/2/7:19:41:12 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/7:19:41:12 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI7F91.tmp
2014/2/7:19:41:22 user USER-PC === Setup ended ===
2014/2/7:19:41:14 user USER-PC === Setup started on USER-PC by user ===
2014/2/7:19:41:14 user USER-PC Path_Length: 149
2014/2/7:19:41:14 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI7F91.tmp
2014/2/7:19:41:14 user USER-PC Launch
2014/2/7:19:41:21 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/7:19:41:21 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI7F91.tmp\Setup\RevitSetup.dll
2014/2/7:19:41:21 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/7:19:41:22 user USER-PC PageOpen LaunchDialog
2014/2/7:19:41:27 user USER-PC PageOpen LicenseDialog
2014/2/7:19:41:42 user USER-PC PageOpen ProductInfoDialog
2014/2/7:20:32:34 user USER-PC === Setup started on USER-PC by user ===
2014/2/7:20:32:34 user USER-PC Path_Length: 149
2014/2/7:20:32:34 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/7:20:32:34 user USER-PC Launch
2014/2/7:20:32:34 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/7:20:32:34 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI81B3.tmp
2014/2/7:20:32:51 user USER-PC === Setup ended ===
2014/2/7:20:32:38 user USER-PC === Setup started on USER-PC by user ===
2014/2/7:20:32:38 user USER-PC Path_Length: 149
2014/2/7:20:32:38 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI81B3.tmp
2014/2/7:20:32:38 user USER-PC Launch
2014/2/7:20:32:49 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/7:20:32:50 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI81B3.tmp\Setup\RevitSetup.dll
2014/2/7:20:32:50 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/7:20:32:51 user USER-PC PageOpen LaunchDialog
2014/2/7:20:36:00 user USER-PC PageOpen LicenseDialog
2014/2/7:20:36:15 user USER-PC PageOpen ProductInfoDialog
2014/2/7:20:36:15 user USER-PC PageOpen ProductSelectionDialog2
2014/2/7:20:36:51 user USER-PC PageOpen FullProgressDialog
2014/2/7:20:36:51 user USER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/2/7:20:36:51 user USER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/7:20:37:31 user USER-PC Install DirectX® Runtime Succeeded
2014/2/7:20:37:31 user USER-PC Download Skipped RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/2/7:20:37:35 user USER-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AI81B3.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:20:45:31 user USER-PC Install Autodesk® Revit® 2014 Succeeded
2014/2/7:20:45:32 user USER-PC Download Skipped RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/2/7:20:45:32 user USER-PC Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI81B3.tmp\_la63DE.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:20:45:49 user USER-PC Install Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/7:20:45:49 user USER-PC Installing Autodesk Workflows 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:20:45:54 user USER-PC Install Autodesk Workflows 2014 Succeeded
2014/2/7:20:45:54 user USER-PC Download Skipped CMILL2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILL201...
2014/2/7:20:45:54 user USER-PC Installing Autodesk Material Library 2014 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:20:46:24 user USER-PC Install Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/7:20:46:24 user USER-PC Download Play CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/2/7:20:50:39 user USER-PC Download Error CMILM2014 <B>No Response from Server</B>Please retry or download again from the website. http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/2/7:20:51:09 user USER-PC Download Error CMILM2014 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/2/7:20:52:39 user USER-PC Download Aborted CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/2/7:20:52:39 user USER-PC Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2014/2/7:20:53:02 user USER-PC Rollback Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/7:20:53:05 user USER-PC Rollback Autodesk Workflows 2014 Succeeded
2014/2/7:20:53:20 user USER-PC Rollback Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/7:20:57:35 user USER-PC Rollback Autodesk® Revit® 2014 Succeeded
2014/2/7:20:57:35 user USER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/7:20:57:36 user USER-PC PageOpen InstallCompleteDialog
2014/2/7:20:58:26 user USER-PC === Setup ended ===
2014/2/28:10:45:24 user USER-PC === Setup started on USER-PC by user ===
2014/2/28:10:45:24 user USER-PC Path_Length: 149
2014/2/28:10:45:24 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/28:10:45:24 user USER-PC Launch
2014/2/28:10:45:24 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/28:10:45:24 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp
2014/2/28:10:45:30 user USER-PC === Setup ended ===
2014/2/28:10:45:26 user USER-PC === Setup started on USER-PC by user ===
2014/2/28:10:45:26 user USER-PC Path_Length: 149
2014/2/28:10:45:26 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp
2014/2/28:10:45:26 user USER-PC Launch
2014/2/28:10:45:28 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/28:10:45:29 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp\Setup\RevitSetup.dll
2014/2/28:10:45:29 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/28:10:45:30 user USER-PC PageOpen LaunchDialog
2014/2/28:10:45:41 user USER-PC PageOpen LicenseDialog
2014/2/28:10:45:47 user USER-PC PageOpen ProductInfoDialog
2014/2/28:10:46:56 user USER-PC PageOpen ProductSelectionDialog2
2014/2/28:10:47:20 user USER-PC PageOpen FullProgressDialog
2014/2/28:10:47:21 user USER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/28:10:47:21 user USER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/28:10:48:07 user USER-PC Install DirectX® Runtime Succeeded
2014/2/28:10:48:07 user USER-PC Download Skipped RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/28:10:48:11 user USER-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:10:57:43 user USER-PC Install Autodesk® Revit® 2014 Succeeded
2014/2/28:10:57:43 user USER-PC Download Skipped RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/28:10:57:44 user USER-PC Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp\_laA6B2.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:10:58:09 user USER-PC Install Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/28:10:58:09 user USER-PC Installing Autodesk Workflows 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:10:58:17 user USER-PC Install Autodesk Workflows 2014 Succeeded
2014/2/28:10:58:17 user USER-PC Download Skipped CMILL2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/28:10:58:17 user USER-PC Installing Autodesk Material Library 2014 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:10:58:55 user USER-PC Install Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/28:10:58:55 user USER-PC Download Play CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:10:59:28 user USER-PC Download Error CMILM2014 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:10:59:38 user USER-PC Download Error CMILM2014 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:03:58 user USER-PC Download Aborted CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:03:58 user USER-PC Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2014/2/28:11:04:26 user USER-PC Rollback Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/28:11:04:30 user USER-PC Rollback Autodesk Workflows 2014 Succeeded
2014/2/28:11:04:42 user USER-PC Rollback Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/28:11:07:59 user USER-PC Rollback Autodesk® Revit® 2014 Succeeded
2014/2/28:11:07:59 user USER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/28:11:07:59 user USER-PC PageOpen InstallCompleteDialog
2014/2/28:11:11:05 user USER-PC === Setup ended ===
2014/2/28:11:13:35 user USER-PC === Setup started on USER-PC by user ===
2014/2/28:11:13:35 user USER-PC Path_Length: 149
2014/2/28:11:13:35 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/28:11:13:35 user USER-PC Launch
2014/2/28:11:13:35 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/28:11:13:35 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI2992.tmp
2014/2/28:11:13:42 user USER-PC === Setup ended ===
2014/2/28:11:13:36 user USER-PC === Setup started on USER-PC by user ===
2014/2/28:11:13:36 user USER-PC Path_Length: 149
2014/2/28:11:13:36 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI2992.tmp
2014/2/28:11:13:36 user USER-PC Launch
2014/2/28:11:13:42 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/28:11:13:42 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI2992.tmp\Setup\RevitSetup.dll
2014/2/28:11:13:42 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/28:11:13:42 user USER-PC PageOpen LaunchDialog
2014/2/28:11:13:46 user USER-PC PageOpen LicenseDialog
2014/2/28:11:13:51 user USER-PC PageOpen ProductInfoDialog
2014/2/28:11:14:49 user USER-PC PageOpen ProductSelectionDialog2
2014/2/28:11:14:55 user USER-PC PageOpen FullProgressDialog
2014/2/28:11:14:56 user USER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/28:11:14:56 user USER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/28:11:15:29 user USER-PC Install DirectX® Runtime Succeeded
2014/2/28:11:15:29 user USER-PC Download Skipped RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/28:11:15:30 user USER-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AI2992.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:11:23:22 user USER-PC Install Autodesk® Revit® 2014 Succeeded
2014/2/28:11:23:22 user USER-PC Download Skipped RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/28:11:23:23 user USER-PC Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI2992.tmp\_la220A.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:11:23:43 user USER-PC Install Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/28:11:23:44 user USER-PC Installing Autodesk Workflows 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:11:23:49 user USER-PC Install Autodesk Workflows 2014 Succeeded
2014/2/28:11:23:49 user USER-PC Download Skipped CMILL2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/28:11:23:49 user USER-PC Installing Autodesk Material Library 2014 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:11:24:22 user USER-PC Install Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/28:11:24:22 user USER-PC Download Play CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:25:27 user USER-PC Download Error CMILM2014 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:32:05 user USER-PC Download Aborted CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:32:05 user USER-PC Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2014/2/28:11:32:35 user USER-PC Rollback Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/28:11:32:39 user USER-PC Rollback Autodesk Workflows 2014 Succeeded
2014/2/28:11:32:50 user USER-PC Rollback Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/28:11:35:46 user USER-PC Rollback Autodesk® Revit® 2014 Succeeded
2014/2/28:11:35:46 user USER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/28:11:50:25 user USER-PC === Setup started on USER-PC by user ===
2014/2/28:11:50:25 user USER-PC Path_Length: 149
2014/2/28:11:50:25 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/28:11:50:25 user USER-PC Launch
2014/2/28:11:50:25 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/28:11:50:25 user USER-PC An instance of setup is already running. Only one instance of setup can run at a time.2014/2/28:11:50:39 user USER-PC === Setup ended ===
2014/2/28:11:35:48 user USER-PC PageOpen InstallCompleteDialog
2014/2/28:11:50:47 user USER-PC === Setup ended ===
2014/2/28:11:53:22 user USER-PC === Setup started on USER-PC by user ===
2014/2/28:11:53:22 user USER-PC Path_Length: 149
2014/2/28:11:53:22 user USER-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/28:11:53:22 user USER-PC Launch
2014/2/28:11:53:22 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/28:11:53:22 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI956F.tmp
2014/2/28:11:53:26 user USER-PC === Setup ended ===
2014/2/28:11:53:23 user USER-PC === Setup started on USER-PC by user ===
2014/2/28:11:53:23 user USER-PC Path_Length: 149
2014/2/28:11:53:23 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI956F.tmp
2014/2/28:11:53:23 user USER-PC Launch
2014/2/28:11:53:24 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/28:11:53:25 user USER-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI956F.tmp\Setup\RevitSetup.dll
2014/2/28:11:53:25 user USER-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/28:11:53:26 user USER-PC PageOpen LaunchDialog
2014/2/28:11:53:29 user USER-PC PageOpen LicenseDialog
2014/2/28:11:53:36 user USER-PC PageOpen ProductInfoDialog
2014/2/28:11:54:24 user USER-PC PageOpen ProductSelectionDialog2
2014/2/28:11:54:30 user USER-PC PageOpen FullProgressDialog
2014/2/28:11:54:31 user USER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/28:11:54:31 user USER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/28:11:55:00 user USER-PC Install DirectX® Runtime Succeeded
2014/2/28:11:55:01 user USER-PC Download Skipped RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/28:11:55:01 user USER-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AI956F.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:12:01:51 user USER-PC Install Autodesk® Revit® 2014 Succeeded
2014/2/28:12:01:52 user USER-PC Download Skipped RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/28:12:01:53 user USER-PC Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI956F.tmp\_la5F0A.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:12:02:05 user USER-PC Install Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/28:12:02:05 user USER-PC Installing Autodesk Workflows 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:12:02:09 user USER-PC Install Autodesk Workflows 2014 Succeeded
2014/2/28:12:02:09 user USER-PC Download Skipped CMILL2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/28:12:02:09 user USER-PC Installing Autodesk Material Library 2014 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/28:12:02:33 user USER-PC Install Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/28:12:02:33 user USER-PC Download Play CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:12:03:50 user USER-PC Download Error CMILM2014 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:12:11:41 user USER-PC Download Aborted CMILM2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:12:11:41 user USER-PC Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2014/2/28:12:12:44 user USER-PC Rollback Autodesk Material Library 2014 - Low Image Library Succeeded
2014/2/28:12:12:46 user USER-PC Rollback Autodesk Workflows 2014 Succeeded
2014/2/28:12:13:00 user USER-PC Rollback Autodesk® Revit® 2014 Language Pack Succeeded
2014/2/28:12:16:58 user USER-PC Rollback Autodesk® Revit® 2014 Succeeded
2014/2/28:12:16:59 user USER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
please help me out... tried so many times still not working for me ..
Try downloading Revit 2014 first and then running the installation. Go to http://www.autodesk.com/products/autodesk-revit-family/free-trial and scroll down to the Desktop Trial. Select the language and OS. Agree to the privacy notice and when the 'INSTALL NOW' button activates click on the down arrow next to it and select 'Browser Download'. Save the file to your local drive. When done downloading then run the installation.
Hope this helps.
Alex
Hello. You look like you may be failing on both the download and the C++ redistributables. I would uninstall all C++ redistributables on the machine and instead of running an “Install Now”, use the “browser download” option to get the full program for install.
Thank you for taking part in our community!
