• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Andreas.Kramer
    Re: Autodesk product failed to send the required value for SERIALNUM
    08-17-2012 07:01 AM in reply to: kevinwhite815
    @ kevinwhite815
    oh yes your are right
    We found now a bad font on our System.
    When we delete it Inventor works.
    But why this error mesasage ?
    It doesent fit to that.
    Please use plain text.
    Active Member
    Stanski
    08-23-2012 01:28 AM in reply to: Andreas.Kramer
    Well we gave up trying in the end (since no useful advice came from Autodesk) and bought a new PC with Windows 7 and thus far Inventor seems to work fine on it.
    Extremely disappointed to not have had a proper solution to this problem.
    Active Member
    Stanski
    10-19-2012 06:14 AM in reply to: Andreas.Kramer
    Problem solved. Got a new machine at work with WIndows 7 on.
    Such a shame there's no support for older platforms. Still fairly cheesed off there was no definitive solution to the problem on XP based machines.
    New Member
    10-25-2012 12:34 AM in reply to: jberns
    I am also having this problem. I am a student running windows xp (sp3) and have reinstalled inventor pro many times, as you have all said, it crashes at startup and then sends an error report. Any help would be much appreciated.
    kevinwhite815
    10-25-2012 03:43 AM in reply to: Andreas.Kramer
    Everyone should try SolidWorks, it is a better program. SolidWorks is more user friendly, easier to manipulate, and hasn't crashed or given me any problems. SolidWorks is also more affordable than Inventor, and more companies use SolidWorks than inventor because of the price.
    New Member
    02-22-2013 08:13 PM in reply to: jberns
    SOLVED!
    OK so i was having this problem along with 3DS max saying something about the .NET framework. So I downloaded the latest >NET (4.5). And Still nothing. Then i went into windows features and realized .NET wasn't even turned on (although i worked before so I don't know what changed or when) but it works now!
