Installation & Licensing
Autodesk inventor cant be installed.
1 REPLY 1
mart324b
355 Views, 1 Reply
Hello, im a student. Thats having problems with autodesk inventor. It seems i can download it, put in the serial key and product key. Then when it goes to install it stops and tells me everything failed to install. Any way to fix this?
My system is:
OS: Microsoft windows 7 home premium.
System model:CX600 MSI
Processor: Intel(R) Core(TM)2 duo cpu T660 @ 2.22.GHz.
Ram: 4 GB
1 REPLY 1
TravisNave
in reply to: mart324b
It's likely a prerequisite installation failure.  Your installation log link on your failure page will tell you exactly what.
Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Autodesk Forums:
Administrator Productivity
