Installation & Licensing
Autodesk inventor 2012 failed to install
2 REPLIES 2
1180 Views, 2 Replies
Hi. I have recently had to factory reset my laptop. I had inventor 2012 running fine before but now when I install I get passed the licence screen and the software fails to install. I have had a look in the forum and have found some fixes that people with coding understanding have been able to fix but I have no expreiance and would really some basic instructions on how to fix and install my software again
the fail log is as follows:
2013/3/25:19:49:57 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/25:19:49:57 Peter JARVIS Launch
2013/3/25:19:54:05 Peter JARVIS === Setup ended ===
2013/3/25:19:50:43 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/25:19:50:43 Peter JARVIS Launch
2013/3/25:19:51:40 Peter JARVIS Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/25:19:51:52 Peter JARVIS Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/3/25:19:51:52 Peter JARVIS Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/3/25:19:51:53 Peter JARVIS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/25:19:52:25 Peter JARVIS PageOpen LaunchDialog
2013/3/25:19:53:49 Peter JARVIS PageOpen LicenseDialog
2013/3/25:19:54:17 Peter JARVIS PageOpen ProductInfoDialog
2013/3/25:19:57:04 Peter JARVIS PageOpen InventorFlavorSelectionDialog
2013/3/25:19:57:04 Peter JARVIS Inventorui==DefaultLanguage: en-us
2013/3/25:19:57:04 Peter JARVIS Inventorui==InstallName: INVENTOR
2013/3/25:19:57:04 Peter JARVIS Inventorui==ProductName: Autodesk Inventor 2012
2013/3/25:19:57:04 Peter JARVIS Inventorui==DisplayName: Autodesk® Inventor® 2012
2013/3/25:19:57:04 Peter JARVIS Inventorui==DeploymentName:
2013/3/25:19:57:04 Peter JARVIS Inventorui==SetupTitle: Autodesk Inventor 2012
2013/3/25:19:57:04 Peter JARVIS Inventorui==ConfigTransform:
2013/3/25:19:57:04 Peter JARVIS Inventorui==ExeParams:
2013/3/25:19:57:04 Peter JARVIS Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2013/3/25:19:57:04 Peter JARVIS Inventorui==SupportLink:
2013/3/25:19:57:04 Peter JARVIS Inventorui==InfotainmentLink:
2013/3/25:19:57:04 Peter JARVIS Inventorui==MsiFileName: inventor.msi
2013/3/25:19:57:04 Peter JARVIS Inventorui==AdminImageConfigName: AdminImagex64
2013/3/25:19:57:04 Peter JARVIS Inventorui==AdminImageRoot:
2013/3/25:19:57:04 Peter JARVIS Inventorui==GetBaseDeploymentName:
2013/3/25:19:57:04 Peter JARVIS Inventorui==DeploymentLocation:
2013/3/25:19:57:04 Peter JARVIS Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2013/3/25:19:57:04 Peter JARVIS Inventorui==InstallDeploymentShortcut:
2013/3/25:19:57:04 Peter JARVIS Inventorui==ModifyDeploymentShortcut:
2013/3/25:19:57:04 Peter JARVIS Inventorui==SetupLockType: 2
2013/3/25:19:57:04 Peter JARVIS Inventorui==SetupNetworkType: 0
2013/3/25:19:57:04 Peter JARVIS Inventorui==SystemLocale: 2057
2013/3/25:19:57:04 Peter JARVIS Inventorui==EvalMsiFilePath: C:\Users\Peter\AppData\Local\Temp\_AIB30A.tmp\SetupRes\eval.msi
2013/3/25:19:57:04 Peter JARVIS Inventorui==EulaPath: C:\Users\Peter\AppData\Local\Temp\_AIB30A.tmp\EULA
2013/3/25:19:57:04 Peter JARVIS Inventorui==InstallLogPath: C:\Users\Peter\AppData\Local\Temp\Inventor2012Install.log
2013/3/25:19:57:04 Peter JARVIS Inventorui==ConfigFile: C:\Users\Peter\AppData\Local\Temp\_AIB30A.tmp\Setup.ini
2013/3/25:19:57:04 Peter JARVIS Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2013/3/25:19:57:04 Peter JARVIS Inventorui==NetworkLogPath:
2013/3/25:19:57:04 Peter JARVIS Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2013/3/25:19:57:15 Peter JARVIS Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2013/3/25:19:57:15 Peter JARVIS PageOpen ProductSelectionDialog2
2013/3/25:19:57:23 Peter JARVIS PageOpen FullProgressDialog
2013/3/25:19:57:25 Peter JARVIS Installing Microsoft Visual C++ 2005 SP1 (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/25:20:01:57 Peter JARVIS Install Microsoft Visual C++ 2005 SP1 (x86) Succeeded
2013/3/25:20:01:58 Peter JARVIS Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/3/25:20:05:07 Peter JARVIS Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/3/25:20:05:07 Peter JARVIS Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Peter\AppData\Local\Temp\vcredist_x86_2010.log
2013/3/25:20:05:34 Peter JARVIS Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2013/3/25:20:05:44 Peter JARVIS PageOpen InstallCompleteDialog
2013/3/25:21:40:55 Peter JARVIS === Setup ended ===
2013/3/25:22:20:32 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/25:22:20:32 Peter JARVIS Launch
2013/3/25:22:21:06 Peter JARVIS === Setup ended ===
2013/3/25:22:20:34 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/25:22:20:34 Peter JARVIS Launch
2013/3/25:22:20:46 Peter JARVIS Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/25:22:20:49 Peter JARVIS Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/3/25:22:20:49 Peter JARVIS Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/3/25:22:20:49 Peter JARVIS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/25:22:20:55 Peter JARVIS PageOpen LaunchDialog
2013/3/25:22:21:35 Peter JARVIS PageOpen LicenseDialog
2013/3/25:22:24:08 Peter JARVIS PageOpen ProductInfoDialog
2013/3/25:22:24:44 Peter JARVIS PageOpen InventorFlavorSelectionDialog
2013/3/25:22:24:44 Peter JARVIS Inventorui==DefaultLanguage: en-us
2013/3/25:22:24:44 Peter JARVIS Inventorui==InstallName: INVENTOR
2013/3/25:22:24:44 Peter JARVIS Inventorui==ProductName: Autodesk Inventor 2012
2013/3/25:22:24:44 Peter JARVIS Inventorui==DisplayName: Autodesk® Inventor® 2012
2013/3/25:22:24:44 Peter JARVIS Inventorui==DeploymentName:
2013/3/25:22:24:44 Peter JARVIS Inventorui==SetupTitle: Autodesk Inventor 2012
2013/3/25:22:24:44 Peter JARVIS Inventorui==ConfigTransform:
2013/3/25:22:24:44 Peter JARVIS Inventorui==ExeParams:
2013/3/25:22:24:44 Peter JARVIS Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2013/3/25:22:24:44 Peter JARVIS Inventorui==SupportLink:
2013/3/25:22:24:44 Peter JARVIS Inventorui==InfotainmentLink:
2013/3/25:22:24:44 Peter JARVIS Inventorui==MsiFileName: inventor.msi
2013/3/25:22:24:44 Peter JARVIS Inventorui==AdminImageConfigName: AdminImagex64
2013/3/25:22:24:44 Peter JARVIS Inventorui==AdminImageRoot:
2013/3/25:22:24:44 Peter JARVIS Inventorui==GetBaseDeploymentName:
2013/3/25:22:24:44 Peter JARVIS Inventorui==DeploymentLocation:
2013/3/25:22:24:44 Peter JARVIS Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2013/3/25:22:24:44 Peter JARVIS Inventorui==InstallDeploymentShortcut:
2013/3/25:22:24:44 Peter JARVIS Inventorui==ModifyDeploymentShortcut:
2013/3/25:22:24:44 Peter JARVIS Inventorui==SetupLockType: 2
2013/3/25:22:24:44 Peter JARVIS Inventorui==SetupNetworkType: 0
2013/3/25:22:24:44 Peter JARVIS Inventorui==SystemLocale: 2057
2013/3/25:22:24:44 Peter JARVIS Inventorui==EvalMsiFilePath: C:\Users\Peter\AppData\Local\Temp\_AI9F6E.tmp\SetupRes\eval.msi
2013/3/25:22:24:44 Peter JARVIS Inventorui==EulaPath: C:\Users\Peter\AppData\Local\Temp\_AI9F6E.tmp\EULA
2013/3/25:22:24:44 Peter JARVIS Inventorui==InstallLogPath: C:\Users\Peter\AppData\Local\Temp\Inventor2012Install.log
2013/3/25:22:24:44 Peter JARVIS Inventorui==ConfigFile: C:\Users\Peter\AppData\Local\Temp\_AI9F6E.tmp\Setup.ini
2013/3/25:22:24:44 Peter JARVIS Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2013/3/25:22:24:44 Peter JARVIS Inventorui==NetworkLogPath:
2013/3/25:22:24:44 Peter JARVIS Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2013/3/25:22:24:52 Peter JARVIS Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2013/3/25:22:24:52 Peter JARVIS PageOpen ProductSelectionDialog2
2013/3/25:22:25:06 Peter JARVIS PageOpen FullProgressDialog
2013/3/25:22:25:07 Peter JARVIS Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Peter\AppData\Local\Temp\vcredist_x86_2010.log
2013/3/25:22:25:11 Peter JARVIS Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2013/3/25:22:25:12 Peter JARVIS PageOpen InstallCompleteDialog
2013/3/25:22:25:54 Peter JARVIS === Setup ended ===
2013/3/26:15:15:31 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/26:15:15:31 Peter JARVIS Launch
2013/3/26:15:15:54 Peter JARVIS === Setup ended ===
2013/3/26:15:15:34 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/26:15:15:34 Peter JARVIS Launch
2013/3/26:15:15:45 Peter JARVIS Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/26:15:15:49 Peter JARVIS Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/3/26:15:15:49 Peter JARVIS Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/3/26:15:15:50 Peter JARVIS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/26:15:15:53 Peter JARVIS PageOpen LaunchDialog
2013/3/26:15:16:44 Peter JARVIS PageOpen LicenseDialog
2013/3/26:15:16:50 Peter JARVIS PageOpen ProductInfoDialog
2013/3/26:17:55:28 Peter JARVIS === Setup ended ===
2013/3/26:19:38:39 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/26:19:38:39 Peter JARVIS Launch
2013/3/26:19:39:35 Peter JARVIS === Setup ended ===
2013/3/26:19:38:44 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/26:19:38:44 Peter JARVIS Launch
2013/3/26:19:39:11 Peter JARVIS Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/26:19:39:17 Peter JARVIS Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/3/26:19:39:17 Peter JARVIS Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/3/26:19:39:18 Peter JARVIS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/26:19:39:35 Peter JARVIS PageOpen LaunchDialog
2013/3/26:19:40:27 Peter JARVIS PageOpen LicenseDialog
2013/3/26:19:40:42 Peter JARVIS PageOpen ProductInfoDialog
2013/3/26:19:42:02 Peter JARVIS PageOpen InventorFlavorSelectionDialog
2013/3/26:19:42:02 Peter JARVIS Inventorui==DefaultLanguage: en-us
2013/3/26:19:42:02 Peter JARVIS Inventorui==InstallName: INVENTOR
2013/3/26:19:42:02 Peter JARVIS Inventorui==ProductName: Autodesk Inventor 2012
2013/3/26:19:42:02 Peter JARVIS Inventorui==DisplayName: Autodesk® Inventor® 2012
2013/3/26:19:42:02 Peter JARVIS Inventorui==DeploymentName:
2013/3/26:19:42:02 Peter JARVIS Inventorui==SetupTitle: Autodesk Inventor 2012
2013/3/26:19:42:02 Peter JARVIS Inventorui==ConfigTransform:
2013/3/26:19:42:02 Peter JARVIS Inventorui==ExeParams:
2013/3/26:19:42:02 Peter JARVIS Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2013/3/26:19:42:02 Peter JARVIS Inventorui==SupportLink:
2013/3/26:19:42:02 Peter JARVIS Inventorui==InfotainmentLink:
2013/3/26:19:42:02 Peter JARVIS Inventorui==MsiFileName: inventor.msi
2013/3/26:19:42:02 Peter JARVIS Inventorui==AdminImageConfigName: AdminImagex64
2013/3/26:19:42:02 Peter JARVIS Inventorui==AdminImageRoot:
2013/3/26:19:42:02 Peter JARVIS Inventorui==GetBaseDeploymentName:
2013/3/26:19:42:02 Peter JARVIS Inventorui==DeploymentLocation:
2013/3/26:19:42:02 Peter JARVIS Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2013/3/26:19:42:02 Peter JARVIS Inventorui==InstallDeploymentShortcut:
2013/3/26:19:42:02 Peter JARVIS Inventorui==ModifyDeploymentShortcut:
2013/3/26:19:42:02 Peter JARVIS Inventorui==SetupLockType: 2
2013/3/26:19:42:02 Peter JARVIS Inventorui==SetupNetworkType: 0
2013/3/26:19:42:02 Peter JARVIS Inventorui==SystemLocale: 2057
2013/3/26:19:42:02 Peter JARVIS Inventorui==EvalMsiFilePath: C:\Users\Peter\AppData\Local\Temp\_AI6084.tmp\SetupRes\eval.msi
2013/3/26:19:42:02 Peter JARVIS Inventorui==EulaPath: C:\Users\Peter\AppData\Local\Temp\_AI6084.tmp\EULA
2013/3/26:19:42:02 Peter JARVIS Inventorui==InstallLogPath: C:\Users\Peter\AppData\Local\Temp\Inventor2012Install.log
2013/3/26:19:42:02 Peter JARVIS Inventorui==ConfigFile: C:\Users\Peter\AppData\Local\Temp\_AI6084.tmp\Setup.ini
2013/3/26:19:42:02 Peter JARVIS Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2013/3/26:19:42:02 Peter JARVIS Inventorui==NetworkLogPath:
2013/3/26:19:42:02 Peter JARVIS Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2013/3/26:19:42:11 Peter JARVIS Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2013/3/26:19:42:11 Peter JARVIS PageOpen ProductSelectionDialog2
2013/3/26:19:42:17 Peter JARVIS PageOpen FullProgressDialog
2013/3/26:19:42:17 Peter JARVIS Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Peter\AppData\Local\Temp\vcredist_x86_2010.log
2013/3/26:19:42:20 Peter JARVIS Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2013/3/26:19:42:21 Peter JARVIS PageOpen InstallCompleteDialog
2013/3/26:19:43:26 Peter JARVIS === Setup ended ===
2013/3/26:21:28:43 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/26:21:28:43 Peter JARVIS Launch
2013/3/26:21:29:19 Peter JARVIS === Setup ended ===
2013/3/26:21:28:45 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/26:21:28:45 Peter JARVIS Launch
2013/3/26:21:29:09 Peter JARVIS Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/26:21:29:10 Peter JARVIS Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/3/26:21:29:10 Peter JARVIS Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/3/26:21:29:11 Peter JARVIS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/26:21:29:14 Peter JARVIS PageOpen LaunchDialog
2013/3/26:21:30:46 Peter JARVIS PageOpen LicenseDialog
2013/3/26:21:32:35 Peter JARVIS PageOpen ProductInfoDialog
2013/3/26:21:33:00 Peter JARVIS PageOpen InventorFlavorSelectionDialog
2013/3/26:21:33:00 Peter JARVIS Inventorui==DefaultLanguage: en-us
2013/3/26:21:33:00 Peter JARVIS Inventorui==InstallName: INVENTOR
2013/3/26:21:33:00 Peter JARVIS Inventorui==ProductName: Autodesk Inventor 2012
2013/3/26:21:33:00 Peter JARVIS Inventorui==DisplayName: Autodesk® Inventor® 2012
2013/3/26:21:33:00 Peter JARVIS Inventorui==DeploymentName:
2013/3/26:21:33:00 Peter JARVIS Inventorui==SetupTitle: Autodesk Inventor 2012
2013/3/26:21:33:00 Peter JARVIS Inventorui==ConfigTransform:
2013/3/26:21:33:00 Peter JARVIS Inventorui==ExeParams:
2013/3/26:21:33:00 Peter JARVIS Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2013/3/26:21:33:00 Peter JARVIS Inventorui==SupportLink:
2013/3/26:21:33:00 Peter JARVIS Inventorui==InfotainmentLink:
2013/3/26:21:33:00 Peter JARVIS Inventorui==MsiFileName: inventor.msi
2013/3/26:21:33:00 Peter JARVIS Inventorui==AdminImageConfigName: AdminImagex64
2013/3/26:21:33:00 Peter JARVIS Inventorui==AdminImageRoot:
2013/3/26:21:33:00 Peter JARVIS Inventorui==GetBaseDeploymentName:
2013/3/26:21:33:00 Peter JARVIS Inventorui==DeploymentLocation:
2013/3/26:21:33:00 Peter JARVIS Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2013/3/26:21:33:00 Peter JARVIS Inventorui==InstallDeploymentShortcut:
2013/3/26:21:33:00 Peter JARVIS Inventorui==ModifyDeploymentShortcut:
2013/3/26:21:33:00 Peter JARVIS Inventorui==SetupLockType: 2
2013/3/26:21:33:00 Peter JARVIS Inventorui==SetupNetworkType: 0
2013/3/26:21:33:00 Peter JARVIS Inventorui==SystemLocale: 2057
2013/3/26:21:33:00 Peter JARVIS Inventorui==EvalMsiFilePath: C:\Users\Peter\AppData\Local\Temp\_AI2A69.tmp\SetupRes\eval.msi
2013/3/26:21:33:00 Peter JARVIS Inventorui==EulaPath: C:\Users\Peter\AppData\Local\Temp\_AI2A69.tmp\EULA
2013/3/26:21:33:00 Peter JARVIS Inventorui==InstallLogPath: C:\Users\Peter\AppData\Local\Temp\Inventor2012Install.log
2013/3/26:21:33:00 Peter JARVIS Inventorui==ConfigFile: C:\Users\Peter\AppData\Local\Temp\_AI2A69.tmp\Setup.ini
2013/3/26:21:33:00 Peter JARVIS Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2013/3/26:21:33:00 Peter JARVIS Inventorui==NetworkLogPath:
2013/3/26:21:33:00 Peter JARVIS Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2013/3/26:21:33:02 Peter JARVIS Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2013/3/26:21:33:03 Peter JARVIS PageOpen ProductSelectionDialog2
2013/3/26:21:33:49 Peter JARVIS PageOpen FullProgressDialog
2013/3/26:21:33:50 Peter JARVIS Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Peter\AppData\Local\Temp\vcredist_x86_2010.log
2013/3/26:21:33:55 Peter JARVIS Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2013/3/27:10:50:45 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/27:10:50:45 Peter JARVIS Launch
2013/3/27:10:50:45 Peter JARVIS Setup Windows update reboot is pending
2013/3/27:10:50:50 Peter JARVIS Setup Autodesk Inventor 2012 Will restart automatically.
2013/3/27:10:50:50 Peter JARVIS === Setup ended ===
2013/3/27:11:01:00 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/27:11:01:00 Peter JARVIS Launch
2013/3/27:11:02:37 Peter JARVIS === Setup ended ===
2013/3/27:11:01:19 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/27:11:01:19 Peter JARVIS Launch
2013/3/27:11:02:15 Peter JARVIS Inventorui== Parameter: Prereq_13 SetupMode:4 InstallState:2 InstallAction:11 Message:
2013/3/27:11:02:15 Peter JARVIS Inventorui== Parameter: Prereq_14 SetupMode:4 InstallState:2 InstallAction:11 Message:
2013/3/27:11:02:23 Peter JARVIS PageOpen LaunchDialog
2013/3/27:11:02:26 Peter JARVIS You are attempting to use a 32-bit installer on a 64-bit operating system.
Please exit and use the 64-bit installer available from your installation media or from Autodesk.com.2013/3/27:11:03:24 Peter JARVIS You are attempting to use a 32-bit installer on a 64-bit operating system.
Please exit and use the 64-bit installer available from your installation media or from Autodesk.com.2013/3/27:11:03:39 Peter JARVIS === Setup ended ===
2013/3/27:11:02:26 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/27:11:02:26 Peter JARVIS Launch
2013/3/27:11:02:26 Peter JARVIS An instance of setup is already running. Only one instance of setup can run at a time.2013/3/27:11:03:40 Peter JARVIS === Setup ended ===
2013/3/27:11:04:06 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/27:11:04:06 Peter JARVIS Launch
2013/3/27:11:05:39 Peter JARVIS === Setup ended ===
2013/3/27:11:04:24 Peter JARVIS === Setup started on JARVIS by Peter ===
2013/3/27:11:04:24 Peter JARVIS Launch
2013/3/27:11:05:21 Peter JARVIS Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/27:11:05:23 Peter JARVIS Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/3/27:11:05:23 Peter JARVIS Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/3/27:11:05:24 Peter JARVIS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2013/3/27:11:05:31 Peter JARVIS PageOpen LaunchDialog
2013/3/27:11:06:40 Peter JARVIS PageOpen LicenseDialog
2013/3/27:11:06:50 Peter JARVIS PageOpen ProductInfoDialog
2013/3/27:11:07:26 Peter JARVIS PageOpen InventorFlavorSelectionDialog
2013/3/27:11:07:26 Peter JARVIS Inventorui==DefaultLanguage: en-us
2013/3/27:11:07:26 Peter JARVIS Inventorui==InstallName: INVENTOR
2013/3/27:11:07:26 Peter JARVIS Inventorui==ProductName: Autodesk Inventor 2012
2013/3/27:11:07:26 Peter JARVIS Inventorui==DisplayName: Autodesk® Inventor® 2012
2013/3/27:11:07:26 Peter JARVIS Inventorui==DeploymentName:
2013/3/27:11:07:26 Peter JARVIS Inventorui==SetupTitle: Autodesk Inventor 2012
2013/3/27:11:07:26 Peter JARVIS Inventorui==ConfigTransform:
2013/3/27:11:07:26 Peter JARVIS Inventorui==ExeParams:
2013/3/27:11:07:26 Peter JARVIS Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2013/3/27:11:07:26 Peter JARVIS Inventorui==SupportLink:
2013/3/27:11:07:26 Peter JARVIS Inventorui==InfotainmentLink:
2013/3/27:11:07:26 Peter JARVIS Inventorui==MsiFileName: inventor.msi
2013/3/27:11:07:26 Peter JARVIS Inventorui==AdminImageConfigName: AdminImagex64
2013/3/27:11:07:26 Peter JARVIS Inventorui==AdminImageRoot:
2013/3/27:11:07:26 Peter JARVIS Inventorui==GetBaseDeploymentName:
2013/3/27:11:07:26 Peter JARVIS Inventorui==DeploymentLocation:
2013/3/27:11:07:26 Peter JARVIS Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2013/3/27:11:07:26 Peter JARVIS Inventorui==InstallDeploymentShortcut:
2013/3/27:11:07:26 Peter JARVIS Inventorui==ModifyDeploymentShortcut:
2013/3/27:11:07:26 Peter JARVIS Inventorui==SetupLockType: 2
2013/3/27:11:07:26 Peter JARVIS Inventorui==SetupNetworkType: 0
2013/3/27:11:07:26 Peter JARVIS Inventorui==SystemLocale: 2057
2013/3/27:11:07:26 Peter JARVIS Inventorui==EvalMsiFilePath: C:\Users\Peter\AppData\Local\Temp\_AIC512.tmp\SetupRes\eval.msi
2013/3/27:11:07:26 Peter JARVIS Inventorui==EulaPath: C:\Users\Peter\AppData\Local\Temp\_AIC512.tmp\EULA
2013/3/27:11:07:26 Peter JARVIS Inventorui==InstallLogPath: C:\Users\Peter\AppData\Local\Temp\Inventor2012Install.log
2013/3/27:11:07:26 Peter JARVIS Inventorui==ConfigFile: C:\Users\Peter\AppData\Local\Temp\_AIC512.tmp\Setup.ini
2013/3/27:11:07:26 Peter JARVIS Inventorui==SetupPath: E:\
2013/3/27:11:07:26 Peter JARVIS Inventorui==NetworkLogPath:
2013/3/27:11:07:26 Peter JARVIS Inventorui==SourceRoot: E:\
2013/3/27:11:07:29 Peter JARVIS Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2013/3/27:11:07:29 Peter JARVIS PageOpen ProductSelectionDialog2
2013/3/27:11:07:36 Peter JARVIS PageOpen FullProgressDialog
2013/3/27:11:07:37 Peter JARVIS Installing Microsoft Visual C++ 2010 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Peter\AppData\Local\Temp\vcredist_x86_2010.log
2013/3/27:11:07:46 Peter JARVIS Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2 REPLIES 2
TravisNave
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
in reply to: TravisNave
thankyou, problem solved
Administrator Productivity
