Installation & Licensing
Autodesk comoponent dosen't work anymore!
1 REPLY 1
266 Views, 1 Reply
AutoCAD Civil 3D was running without problems but someday when I tried to open it, it appeared a window saying: checking license data. Right after this appears another window saying: Autodesk component dosen't work anymore. The Programm starts then like normal but I can do nothing and when I click somewhere another window appears, saying: programm dosen't answer anymore, it will be closed and searched for a solution.
Since this problem appeared I uninstalled und reinstalled it about 10 times and set up my laptop new but the error appeared still everytime I tried to run the programm. Yesterday I registered my serialnumber and produktkey, but because the programm isn't running I couldn't give all the asked data, so I don't know exactly if it worked.
I need the programm urgently for studentprojekts and really need help!!
Greetings Angelika Peeters
1 REPLY 1
dembkod
angi.peeters
Hello. If you uninstall and reinstall more than twice and it doesn’t help, you are likely uninstalling the wrong thing.
Uninstall the program.
Uninstall the Visual C++ entries on the system
Uninstall NET
Try to uninstall the program again using the Msfixit tool:
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Update your Graphics card driver
Now install and test
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
