AutoCAD Civil 3D was running without problems but someday when I tried to open it, it appeared a window saying: checking license data. Right after this appears another window saying: Autodesk component dosen't work anymore. The Programm starts then like normal but I can do nothing and when I click somewhere another window appears, saying: programm dosen't answer anymore, it will be closed and searched for a solution.
Since this problem appeared I uninstalled und reinstalled it about 10 times and set up my laptop new but the error appeared still everytime I tried to run the programm. Yesterday I registered my serialnumber and produktkey, but because the programm isn't running I couldn't give all the asked data, so I don't know exactly if it worked.
I need the programm urgently for studentprojekts and really need help!!
Greetings Angelika Peeters
Hello. If you uninstall and reinstall more than twice and it doesn’t help, you are likely uninstalling the wrong thing.
Uninstall the program.
Uninstall the Visual C++ entries on the system
Uninstall NET
Try to uninstall the program again using the Msfixit tool:
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Update your Graphics card driver
Now install and test
Thank you for taking part in our community!
