First, after installing AutoDesk Vault 2011 on a working 2010 setup, we can no longer access licenses. In the morning we were getting Autocad electrical licenses fine after updating the license to 2011. Then this afternoon we installed 2011 Vault on the server. Nothing else. Now we can not get license files anylonger.
Sooo, I see that there is a new Autodesk Vault 2011 Update 1. I get it. Read the dangerous warning about doing everything right. Follow the instructions to the T. And the install fails with the error " Error 1305. Error reading file: C:/windows/installer/793fa.msi. Verify that the file exists and that you can access it."
I do so. It exists. Right where you say you can't find it. I can access it.
So, after trying again and again, I do access it. It is the change / remove file for Vault server. Now the other crazy complaint is that there are no instruction for determining if the Update 1 has been installed or not. Pretty bad designing on someone's part. But the real problem is that we still are dead in the water with respect to getting licenses.
The FLexLM license manager does show that there are available licenses and that none are checked out.
Help.?!?
