Installation & Licensing
Autodesk Vault -for Autodesk Inventor Prof 2011.
2 REPLIES 2
email2basit
350 Views, 2 Replies
Problem 1:::
With Autodesk Inventor 2011 Professional Version ,we are unable to Configure “VaultClient” application.
Autodesk Vault does not install with “Inventor 2011 Professional”. Along with installation of AutoCAD Mech2011, “Autodesk VaultClient” install automatically.
When we launch “Inventor 2011 Professional” and try to Login with Autodesk Vault error occurs (attached)
How can we Configure  Autodesk vault with Inventor 2011 Professional.?
Is Autodesk Vault Client and Autodesk Vault Server differnet application?
OS : Windows 7 Home(64 Bit) and Windows 7 Ultimate (32 Bit)
Problem2:::
How can we configure IIS on win 7.0 Home64 Bit
2 REPLIES 2
DarrenP
in reply to: email2basit
1. is Vault Server running on the same machine as inventor and Vault Client if not you need put in the server name instead
of local host
2. I don't think windows 7 home edition has IIS in it you may need to upgrade to Pro or higher
DarrenP
email2basit
 i have chaged OS from win 7 home to Ultimate.
IIS is not working fine.
Tryinng to find " Vault Server" setup
Would like to run run Inventor Prof, Vault Client and Vault Server on same machine
Administrator Productivity
