Installation & Licensing
Active Contributor nmt
Active Contributor
nmt
Message 1 of 7 (1,434 Views)
Autodesk Vault 2014 Server Installati​on Error
1434 Views, 6 Replies
04-21-2013 11:59 AM
I have Vault Basic 2013 and 2013 server installed and it has worked flawless.
Now I am trying to install Vault 2014.
Vault basic client installed without any problems but when I try to install Vault Server 2014 I get:
Error 29001 content type " expected text.xml.
Any ideas?
Best regards / H. Nilsson
HP Elite Book
Win 7 / 64
8 GB
500GB HDD
Product Support
Kevin.Jaufmann-Ludwig
Message 2 of 7 (1,347 Views)
Re: Autodesk Vault 2014 Server Installati​on Error
04-24-2013 06:53 AM in reply to: nmt
Hi H. Nilsson,
even though this is pretty old but have you checked this for example:
http://forums.autodesk.com/t5/Autodesk-Vault/Error-29001-Vault-management-error/td-p/1639817
Some useuful hints which still apply.
Have you checked the installation logfile (should be in the tempfoder)?
However my personal advice for you is to uninstall IIS and .NET and let the Vault Server 2014 setup install and configure IIS and .NET
By the way: hopefully you have a backup of your previous Vault Server 2013 installation (if you need data from vault 2013).
Kevin Jaufmann-Ludwig
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Active Contributor
nmt
Message 3 of 7 (1,331 Views)
04-24-2013 09:50 AM in reply to: Kevin.Jaufmann-Ludwig
Hi Kevin,
thanks for your response.
Active Contributor
nmt
Message 4 of 7 (1,329 Views)
04-24-2013 09:58 AM in reply to: nmt
Hi Kevin,
I will look in to the threads / tips you mentioned.
However it seems temptating to uninstall IIS and .net.
I will try this during weekend.
My Vaulted files are backed up every evening, do I need to make any further steps before reinstalling?
Best Regards / H. Nilsson
Product Support
Message 5 of 7 (1,309 Views)
04-25-2013 12:48 AM in reply to: nmt
no I don´t think so.
Maybe it is necessary to uninstall all components that Vault uses.
The components that Vault Server uses are listed here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18562673&linkID=9261340
Besides IIS and .NET the problem might be related to SQL as well.
Autodesk, Inc.
Active Contributor
nmt
Message 6 of 7 (1,306 Views)
04-25-2013 01:50 AM in reply to: Kevin.Jaufmann-Ludwig
Thanks Kevin.,
I will give it a try during weekend.
I just took a quick look at the list of components installed by Vault server 2013 and noticed:
Microsoft MSXML6, MSXML4 installed.
.net framework 3,5, .net framework 4,5 installed.
Could this be a problem?
Active Contributor
nmt
Message 7 of 7 (1,179 Views)
05-09-2013 01:17 AM in reply to: nmt
it´s me again.
I have tried all your solutions but with no luck.
I even took the time to throw out my old HDD, replaced it with a new SSD drive, made a clean install and the problem remains the same!!!
Hopefully someone has a solution??
Btw after failing I installed Vault server and client 2013 and that version works perfectly.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
