Installation & Licensing
Autodesk Software on a Zenworks image
1 REPLY 1
kchong
708 Views, 1 Reply
I would like to install Autodesk in my computer labs using Zenworks. They are all single seats using the same serial number. I was thinking I would install but not activate the software on my main computer. After the image I would activate autodesk. Does anyone have any thoughts about imaging autodesk software? Does it work? If so what do I need to do for the imaging process to be successful?
1 REPLY 1
TravisNave
in reply to: kchong
Activation from a disk image almost never works.  Because you have a multi-seat stand-alone serial number, you might have better luck with this process.  But there is no guarantee that it will work.  Given this, have you considered network activating your licenses and running a license manager?  Network licensed software images perfectly and you can effectively install to an unlimited amount of machines.
Autodesk Forums:
Administrator Productivity
