• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    autodeskasad
    Autodesk Showcase 2012- Help needed
    895 Views, 9 Replies
    08-10-2011 07:45 AM
    I have installed Autodesk showcase 2012 and when I try to open it up, I see an error saying " Autodesk Showcase 2012 SP1: window initialization failed. Your hardware configuration may not be supported". Please view the image below:
    I have installed the service pack but still it showing the same error. Any suggestions and comments would be much appreciated,
    Thanks.
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: Autodesk Showcase 2012- Help needed
    08-10-2011 07:51 AM in reply to: autodeskasad
    what are your system requirements?
    it says in the error message that your hardware may not be supported
    Active Member
    autodeskasad
    08-10-2011 08:13 AM in reply to: DarrenP
    Kindly view the attachments for the specifications of my laptop.
    *Expert Elite*
    DarrenP
    08-10-2011 08:15 AM in reply to: autodeskasad
    thats a hardware problem
    you need to upgrade your graphics card to run showcase
    you can not run showcase on that video card
    Active Member
    autodeskasad
    08-10-2011 08:35 AM in reply to: DarrenP
    Can you suggest me which graphic card should I have and if it is possible to upgrade a graphic card on a dell studio laptop?
    *Expert Elite*
    DarrenP
    08-10-2011 08:39 AM in reply to: autodeskasad
    you need to talk to dell about upgrading the laptop
    you can use this to determine a graphics card: http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
    Active Member
    autodeskasad
    08-10-2011 08:45 AM in reply to: DarrenP
    ok, thanks alot for all the inforamation. :smileyhappy:
    Distinguished Contributor
    02-02-2012 01:12 AM in reply to: autodeskasad
    I get the same error. Z400 workstation (6Gb) with Quadro 600 graphics card (1Gb). Windows XP x64 SP2.
    IV2013
    *Expert Elite*
    DarrenP
    02-02-2012 05:30 AM in reply to: signmeup
    did you read this whole thread?
    02-02-2012 05:34 AM in reply to: DarrenP
    is that a trick question?
    IV2013
