Hello, I've installed this 2 times, on two seprate computers. However, each time its done downloading (i used a download manager and my internet is releatively fast) and i get to the last stage, it saids that
Installation complete. Some PRoducts failed to install
Autodesk Revit Arcitecture 2012 - NOPE
Autodesk design review 2012 - NOPE
Autodesk Material library 2012- Nope
and it gives me an error message
2012/5/27:03:26:54 Temp TEMP-HP === Setup started on TEMP-HP by Temp ===
2012/5/27:03:26:54 Temp TEMP-HP Launch
2012/5/27:03:27:53 Temp TEMP-HP === Setup ended ===
2012/5/27:03:27:54 Temp TEMP-HP PageOpen LaunchDialog
2012/5/27:03:39:41 Temp TEMP-HP PageOpen LicenseDialog
2012/5/27:04:08:23 Temp TEMP-HP PageOpen ProductInfoDialog
2012/5/27:04:08:42 Temp TEMP-HP PageOpen ProductSelectionDialog2
2012/5/27:04:08:47 Temp TEMP-HP PageOpen FullProgressDialog
2012/5/27:04:08:47 Temp TEMP-HP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Temp\AppData\Local\Temp\vcredist_x86_2010.log
2012/5/27:04:08:49 Temp TEMP-HP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/5/27:04:21:51 Temp TEMP-HP === Setup started on TEMP-HP by Temp ===
2012/5/27:04:21:51 Temp TEMP-HP Launch
2012/5/27:04:22:41 Temp TEMP-HP === Setup ended ===
2012/5/27:13:30:08 Temp TEMP-HP === Setup started on TEMP-HP by Temp ===
2012/5/27:13:30:08 Temp TEMP-HP Launch
2012/5/27:13:31:00 Temp TEMP-HP === Setup ended ===
2012/5/27:13:31:01 Temp TEMP-HP PageOpen LaunchDialog
2012/5/27:13:36:12 Temp TEMP-HP PageOpen LicenseDialog
2012/5/27:13:47:45 Temp TEMP-HP PageOpen ProductInfoDialog
2012/5/27:13:50:49 Temp TEMP-HP PageOpen ProductSelectionDialog2
2012/5/27:13:50:55 Temp TEMP-HP PageOpen FullProgressDialog
2012/5/27:13:50:55 Temp TEMP-HP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Temp\AppData\Local\Temp\vcredist_x86_2010.log
2012/5/27:13:50:57 Temp TEMP-HP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/5/27:14:36:56 Temp TEMP-HP === Setup started on TEMP-HP by Temp ===
2012/5/27:14:36:56 Temp TEMP-HP Launch
2012/5/27:14:37:44 Temp TEMP-HP === Setup ended ===
2012/5/27:14:36:57 Temp TEMP-HP === Setup started on TEMP-HP by Temp ===
2012/5/27:14:36:57 Temp TEMP-HP Launch
2012/5/27:14:37:45 Temp TEMP-HP PageOpen LaunchDialog
2012/5/27:14:38:39 Temp TEMP-HP PageOpen LicenseDialog
2012/5/27:14:38:49 Temp TEMP-HP PageOpen ProductInfoDialog
2012/5/27:14:39:32 Temp TEMP-HP PageOpen ProductSelectionDialog2
2012/5/27:14:39:46 Temp TEMP-HP PageOpen FullProgressDialog
2012/5/27:14:39:46 Temp TEMP-HP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Temp\AppData\Local\Temp\vcredist_x86_2010.log
2012/5/27:14:39:48 Temp TEMP-HP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/5/27:15:43:49 Temp TEMP-HP === Setup started on TEMP-HP by Temp ===
2012/5/27:15:43:49 Temp TEMP-HP Launch
2012/5/27:15:44:38 Temp TEMP-HP === Setup ended ===
2012/5/27:15:43:50 Temp TEMP-HP === Setup started on TEMP-HP by Temp ===
2012/5/27:15:43:50 Temp TEMP-HP Launch
2012/5/27:15:44:39 Temp TEMP-HP PageOpen LaunchDialog
2012/5/27:15:46:02 Temp TEMP-HP PageOpen LicenseDialog
2012/5/27:15:46:11 Temp TEMP-HP PageOpen ProductInfoDialog
2012/5/27:15:46:15 Temp TEMP-HP PageOpen ProductSelectionDialog2
2012/5/27:15:46:19 Temp TEMP-HP PageOpen FullProgressDialog
2012/5/27:15:46:19 Temp TEMP-HP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Temp\AppData\Local\Temp\vcredist_x86_2010.log
2012/5/27:15:46:21 Temp TEMP-HP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/5/27:15:46:21 Temp TEMP-HP PageOpen InstallCompleteDialog
2012/5/27:15:51:27 Temp TEMP-HP === Setup ended ===
2012/5/27:16:01:23 Temp TEMP-HP === Setup started on TEMP-HP by Temp ===
2012/5/27:16:01:23 Temp TEMP-HP Launch
2012/5/27:16:02:13 Temp TEMP-HP === Setup ended ===
2012/5/27:16:02:13 Temp TEMP-HP PageOpen LaunchDialog
2012/5/27:16:06:09 Temp TEMP-HP PageOpen LicenseDialog
2012/5/27:18:06:39 Temp TEMP-HP PageOpen ProductInfoDialog
2012/5/27:18:06:53 Temp TEMP-HP PageOpen ProductSelectionDialog2
2012/5/27:18:07:08 Temp TEMP-HP PageOpen FullProgressDialog
2012/5/27:18:07:08 Temp TEMP-HP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Temp\AppData\Local\Temp\vcredist_x86_2010.log
2012/5/27:18:07:10 Temp TEMP-HP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Temp-HP Is my computers name =/ Could somebody please help me?
This should help.
Danny
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
