Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Autodesk Revit Architectu re 2013 installati on error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
NOTE: my computer knowledge is zero and computer language and technicalities go above and beyond my mind so please bear with me.
Though the topic subject may says it all, Revit and I go way back when I first installed it (successful install) but it didn't use to launch at all. I tried to uninstall it and that gave me error too. I figured that a lot of people were having the same problem so I found the best related topic to mine and did a few things here and there but nothing seemed to work so I finally got a plug-in program recommended in the threads and UNISTALLED Revit Architecture with microsoft FixIt appication.
I just upgraded all my previous versions of AutoCad and 3dsMax so I thought why not to install Revit Architecture 2013 and give it a shot weather or not it will install.
Obviously REVIT ARCHITECTURE 2013 is NOT installing at all. and here are the error messages I am receiving on the initial setup
PLEASE help me with this problem. So I need a clean up? What can I possibly do to get this working.
I am using Windows 7 64-bit operating system
Re: Autodesk Revit Architectu re 2013 installati on error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
and this is the error messaging I am getting upon Launching the Autodesk Revit 2013 Setup (not Revit Architecture) from download manager (Autodesk_Revit_2013_English_Win_32_64bit_wi_en-US
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It seems as though your Windows is in pretty bad shape, actually.
Start here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Then make sure your firewall is disabled temporarily and that you have local admin rights to install. You willl need to have unrestricted access to the Internet to complete the Revit download.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Autodesk Revit Architectu re 2013 installati on error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Nope, even after i did as u told so, as soon as i click "Autodesk_Revit_2013_English_Win_32_64bit_wi_en-US
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Revit requires additional downloading. So clearly your computer, firewall, proxy server, web gateway, something... is blocking that access.
