• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Autodesk Revit Architecture 2013 installation error
    621 Views, 4 Replies
    11-13-2012 12:33 PM
    NOTE: my computer knowledge is zero and computer language and technicalities go above and beyond my mind so please bear with me.
    Though the topic subject may says it all, Revit and I go way back when I first installed it (successful install) but it didn't use to launch at all. I tried to uninstall it and that gave me error too. I figured that a lot of people were having the same problem so I found the best related topic to mine and did a few things here and there but nothing seemed to work so I finally got a plug-in program recommended in the threads and UNISTALLED Revit Architecture with microsoft FixIt appication.
    I just upgraded all my previous versions of AutoCad and 3dsMax so I thought why not to install Revit Architecture 2013 and give it a shot weather or not it will install.
    Obviously REVIT ARCHITECTURE 2013 is NOT installing at all. and here are the error messages I am receiving on the initial setup
    PLEASE help me with this problem. So I need a clean up? What can I possibly do to get this working.
    I am using Windows 7 64-bit operating system
    Please use plain text.
    New Member
    Re: Autodesk Revit Architecture 2013 installation error
    11-13-2012 01:24 PM in reply to: nmobeen2
    and this is the error messaging I am getting upon Launching the Autodesk Revit 2013 Setup (not Revit Architecture) from download manager (Autodesk_Revit_2013_English_Win_32_64bit_wi_en-US_Setup1)
    TravisNave
    11-13-2012 02:09 PM in reply to: nmobeen2
    It seems as though your Windows is in pretty bad shape, actually.
    Start here:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16508079&linkID=9240617
    Then make sure your firewall is disabled temporarily and that you have local admin rights to install.  You willl need to have unrestricted access to the Internet to complete the Revit download.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    11-15-2012 11:12 PM in reply to: TravisNave
    Nope, even after i did as u told so, as soon as i click "Autodesk_Revit_2013_English_Win_32_64bit_wi_en-US_Setup " it shows me this message
    TravisNave
    11-16-2012 07:14 AM in reply to: nmobeen2
    Revit requires additional downloading.  So clearly your computer, firewall, proxy server, web gateway, something... is blocking that access.
    Travis Nave
