• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Autodesk Revit Architecture 2013 - Installation won't complete
    640 Views, 3 Replies
    12-26-2012 04:41 PM
    I have tried to install now from autodesk.com, would not even start installing. Then tried to download now and managed to start setup until the installation stalled.
    - Firewall off
    - Anti virus deactivated
    - Autodesk.com added as a trusted site
    One thing though, I wasn't given the choice to run or save the install now and download now file, only to save it.
    So please help me configuring what can be the problem. Thank you
    Please use plain text.
    DarrenP
    Re: Autodesk Revit Architecture 2013 - Installation won't complete
    12-27-2012 06:43 AM in reply to: tienwoodsen
    its not stalled its downloading the revit content in the background
    which depends on your internet speed can take a long time
    TravisNave
    12-27-2012 07:36 AM in reply to: DarrenP
    Darren is right. On slow connections I have seen this take 8 hours. If your connection is slow, start the installer and let it run overnight.  It'll be installed in the morning.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    12-27-2012 03:31 PM in reply to: DarrenP
    Thank you Daren and Trevis; I'll try installing AR_2013 again, now I know I have to be patient. I have closed the xbox and the other laptops and I managed to install AR_2013 in under an hour! Thanx again. Tien
