Installation & Licensing
Autodesk Revit Architecture 2013 - Installation won't complete
3 REPLIES 3
tienwoodsen
2588 Views, 3 Replies
I have tried to install now from autodesk.com, would not even start installing. Then tried to download now and managed to start setup until the installation stalled.
- Firewall off
- Anti virus deactivated
- Autodesk.com added as a trusted site
One thing though, I wasn't given the choice to run or save the install now and download now file, only to save it.
So please help me configuring what can be the problem. Thank you
3 REPLIES 3
DarrenP
in reply to: tienwoodsen
its not stalled its downloading the revit content in the background
which depends on your internet speed can take a long time
DarrenP
TravisNave
in reply to: DarrenP
Darren is right. On slow connections I have seen this take 8 hours. If your connection is slow, start the installer and let it run overnight.  It'll be installed in the morning.
Autodesk Forums:
tienwoodsen
Thank you Daren and Trevis; I'll try installing AR_2013 again, now I know I have to be patient. I have closed the xbox and the other laptops and I managed to install AR_2013 in under an hour! Thanx again. Tien
Administrator Productivity
