Installation & Licensing
Autodesk Revit 2015 on Mac using Bootcamp with Windows 7 Professional
2 REPLIES 2
1175 Views, 2 Replies
I've installed windows profession under bootcamp and are trying to install Autodesk Revit 2015, Even though Autodesk say that the OS is supported when it comes to install from the popup installation menu is is locked out and says the the OS is not supported
2 REPLIES 2
TravisNave
Minimum requirements are Windows 7 SP1.  You might not have the service pack installed for Windows yet.
Autodesk Forums:
in reply to: TravisNave
Perfect, simple as that !
Thank you
Dezine 1
Administrator Productivity
