I've installed windows profession under bootcamp and are trying to install Autodesk Revit 2015, Even though Autodesk say that the OS is supported when it comes to install from the popup installation menu is is locked out and says the the OS is not supported
Solved by TravisNave. Go to Solution.
Minimum requirements are Windows 7 SP1. You might not have the service pack installed for Windows yet.
