Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Autodesk Quantity takeoff 2012 - "Can't find End User License Agreement" ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have downloaded Autodesk Quantity Takeoff 2012 from students.autodesk.com (and have also tried to download from usa.autodesk.com), but when i open setup.exe and choses install i get the message:
And the installation program closes down. Why cant i install?
I have tried the following - suggested by Derrick from autodesk support center:
"If this happens when you download and try to install the software from the Education Community this means there is a problem with the installation file, and it will not work on your computer.
To resolve this issue, please do the following:
1. Delete the file you downloaded.
2. Next go to Start> Accessories> System Tools> Disc Cleanup and run that utility to clear your temp files, etc.
3. Reboot your machine.
4. Turn off your security software - anti-virus programs, firewalls, etc. can block downloads.
5. Go to your country's main Autodesk website and download the trial version of the software*.
6. Install the product.
7. Re-enable your security software.
8. Get your product key and serial number from the page you downloaded from.
9. Launch the product you are trying to activate.
10. A splash screen should come up with two buttons.
11. Click on the one labeled “Activate” and follow the prompts.
*The trial version is the same as the commercial, free student, and purchased education version; the only difference is that it lacks a serial number. The only difference between the commercial, free, and purchased educational versions is their serial numbers.
What to do?
- Thanks
Re: Autodesk Quantity takeoff 2012 - "Can't find End User License Agreement
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
copy "all other countries.rtf" file from the folder named EULA2 to EULA in the installation directory.
If you have a DVD you will need to copy the content to local hard disk before you do this.
please post the result.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I also have same problem, i already followed the step which was posted on top trying to solve, but it's failed
i have no DVD, I download Quantity Takeoff from Autodesk Education Community
Can i find installation directory on the this website?
Thanks for repling
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you have downloaded the installation files are in c:\autodesk
Hashim Mundol
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i already copied the file "all other countries.rtf" file from the folder named EULA2 to EULA
still got a same result "Can't find End License Agreement"
enclosed error message
thanks for repling
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you change the country in the license agreement does it work,
May I know which country you are selecting (selected by default)
thanks
Hashim Mundol
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
is it not because it Can't find the united kingdom End User License Agreement?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
it should take "All Other Countries" file.
Hashim Mundol
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It worked!
I did what you described, and the program is install without any problems..
Thanks a lot!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I have followed your advice. I have copied "all other countries.rtf" file from the folder named EULA2 to EULA in the installation directory. And it worked.
Thank you so much.
Antonia Del Debbio
