• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Autodesk Product Design Suite Ultimate 2012 Error:1720
    500 Views, 4 Replies
    03-27-2012 01:55 PM
    Hello
    I recieved a error message and installation will not finish. Please see the attached image.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Autodesk Product Design Suite Ultimate 2012 Error:1720
    03-27-2012 02:10 PM in reply to: KrisLizak
    You might have an issue with your installed VB Script.  Try creating a new user profile with local admin rights and installing as the new user.  If that doesn't work, make sure you have the latest version of the Windows Installer.
    Error 1720 doesn't happen very often and it indicates a problem with your Windows and not the Autodesk software.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    03-28-2012 03:15 AM in reply to: KrisLizak
    That's what I tohught. I will give it a try and let you know.
    New Member
    09-23-2012 09:59 AM in reply to: KrisLizak
    i had the same problem.. could you send me a link to get windows installer?? thanks:smileyhappy :smileyhappy:
    philip.s
    09-24-2012 12:01 PM in reply to: lilstinger13
    Hi Aaron,
    What version of Windows are you running? For XP or VIsta, you can download directly from Microsoft. If you are running Windows 7, please see the following articles (article1, article2, article3).
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
