Installation & Licensing
Autodesk Network License Manager for Mac OS X 10.6 (Snow Leopard)
6 REPLIES 6
1337 Views, 6 Replies
Hi Guys,
Good day. We just finished networking our 2 Computer Labs all running Macs (iMacs and MacPros) workstations running on Mac OS X 10.6 Snow Leopard. Now the plan is to make our mentor's workstation (MacPro) as a server for the Maya Software. I've already downloaded the software and also got the license file. My concern now is the Autodesk Network License Manager, FlexNet. I was able to download the FlexNet Publisher License Server 11.11.1.2 but it won't continue when I installed it to our mentor's workstation. Can you provide me a link that works as a License Manager that is also compatible with Mac OS X 10.6.8 or is there another Network License Manager that you can recommend for Mac.
Thanks.
Lloyd
6 REPLIES 6
Hi Guys,
Good day. Following the steps in installing the autodesk network license manager for Mac OS X 10.6, below is its message in Terminal:
CGI52Mentor:flexnetserver sysad$ ./lmgrd -c ENCSU2014enlicense.lic -ldebug_log_path
CGI52Mentor:flexnetserver sysad$  9:07:25 (lmgrd) -----------------------------------------------
 9:07:25 (lmgrd)   Please Note:
 9:07:25 (lmgrd)
 9:07:25 (lmgrd)   This log is intended for debug purposes only.
 9:07:25 (lmgrd)   In order to capture accurate license
 9:07:25 (lmgrd)   usage data into an organized repository,
 9:07:25 (lmgrd)   please enable report logging. Use Flexera Software LLC's
 9:07:25 (lmgrd)   software license administration  solution,
 9:07:25 (lmgrd)   FlexNet Manager, to  readily gain visibility
 9:07:25 (lmgrd)   into license usage data and to create
 9:07:25 (lmgrd)   insightful reports on critical information like
 9:07:25 (lmgrd)   license availability and usage. FlexNet Manager
 9:07:25 (lmgrd)   can be fully automated to run these reports on
 9:07:25 (lmgrd)   schedule and can be used to track license
 9:07:25 (lmgrd)   servers and usage across a heterogeneous
 9:07:25 (lmgrd)   network of servers including Windows NT, Linux
 9:07:25 (lmgrd)   and UNIX. Contact Flexera Software LLC at
 9:07:25 (lmgrd)   www.flexerasoftware.com for more details on how to
 9:07:25 (lmgrd)   obtain an evaluation copy of FlexNet Manager
 9:07:25 (lmgrd)   for your enterprise.
 9:07:25 (lmgrd)
 9:07:25 (lmgrd)
 9:07:25 (lmgrd)
 9:07:25 (lmgrd) "CGI52Mentor.local": Not a valid server hostname, exiting.
 9:07:25 (lmgrd) Valid license server system hosts are: "CGI52MENTOR"
 9:07:25 (lmgrd) Using license file "ENCSU2014enlicense.lic"
Is there another way to run our license server?
Thanks.
Lloyd
JTBWorld
The hostname in the license file must match the actual hostname exactly.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
TravisNave
in reply to: JTBWorld
Jimmy is right.  He always is.  Smiley Very Happy
Just change the hostname in the LIC to match the required name listed in the error status.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thank you so much Jimmy. It TOTALLY worked. Thank you very much.
Lloyd
in reply to: TravisNave
Thank you too Jimmy for the follow up. It totally worked.
hugh.weisman
Ok. I'm resurrecting an old thread. We seem to have similar problem, We;re trying to license autocad 2015 on a Mac Mini running Snow Leopard Server 10.6. We obtained our license and installed NLM on the server. When we run lmgrd, we've been bedeviled with error messages such as the one below indicating that the hostname in the license file is not a valid license server system host. We'll change the name to match and receive a similar message. We;re pulling our hair out.
MACSERVER:flexnetserver hughweisman$ sudo ./lmgrd -c /var/flexlm/adsk_server.lic14:00:05 (lmgrd) -----------------------------------------------
14:00:05 (lmgrd)   Please Note:
14:00:05 (lmgrd) Server's System Date and Time: Thu May 08 2014 14:00:05 EDT
14:00:05 (lmgrd) SLOG: Summary LOG statistics is enabled.
14:00:05 (lmgrd) The license server manager (lmgrd) running as root:
14:00:05 (lmgrd)            This is a potential security problem
14:00:05 (lmgrd)            and is not recommended.
MACSERVER:flexnetserver hughweisman$ 14:00:06 (lmgrd) "MACSERVER": Not a valid server hostname, exiting.
14:00:06 (lmgrd) Valid license server system hosts are: "MACSERVER.local"
14:00:06 (lmgrd) Using license file "/var/flexlm/adsk_server.lic"
Administrator Productivity
