Hi Guys,
Solved by TravisNave. Go to Solution.
Solved by JTBWorld. Go to Solution.
Hi Guys,
CGI52Mentor:flexnetserver sysad$ ./lmgrd -c ENCSU2014enlicense.lic -ldebug_log_path
CGI52Mentor:flexnetserver sysad$ 9:07:25 (lmgrd) -----------------------------------------------
9:07:25 (lmgrd) Please Note:
9:07:25 (lmgrd)
9:07:25 (lmgrd) This log is intended for debug purposes only.
9:07:25 (lmgrd) In order to capture accurate license
9:07:25 (lmgrd) usage data into an organized repository,
9:07:25 (lmgrd) please enable report logging. Use Flexera Software LLC's
9:07:25 (lmgrd) software license administration solution,
9:07:25 (lmgrd) FlexNet Manager, to readily gain visibility
9:07:25 (lmgrd) into license usage data and to create
9:07:25 (lmgrd) insightful reports on critical information like
9:07:25 (lmgrd) license availability and usage. FlexNet Manager
9:07:25 (lmgrd) can be fully automated to run these reports on
9:07:25 (lmgrd) schedule and can be used to track license
9:07:25 (lmgrd) servers and usage across a heterogeneous
9:07:25 (lmgrd) network of servers including Windows NT, Linux
9:07:25 (lmgrd) and UNIX. Contact Flexera Software LLC at
9:07:25 (lmgrd) www.flexerasoftware.com for more details on how to
9:07:25 (lmgrd) obtain an evaluation copy of FlexNet Manager
9:07:25 (lmgrd) for your enterprise.
9:07:25 (lmgrd)
9:07:25 (lmgrd)
9:07:25 (lmgrd)
9:07:25 (lmgrd) "CGI52Mentor.local": Not a valid server hostname, exiting.
9:07:25 (lmgrd) Valid license server system hosts are: "CGI52MENTOR"
9:07:25 (lmgrd) Using license file "ENCSU2014enlicense.lic"
Is there another way to run our license server?
Thanks.
Lloyd
The hostname in the license file must match the actual hostname exactly.
Jimmy is right. He always is.
Just change the hostname in the LIC to match the required name listed in the error status.
Ok. I'm resurrecting an old thread. We seem to have similar problem, We;re trying to license autocad 2015 on a Mac Mini running Snow Leopard Server 10.6. We obtained our license and installed NLM on the server. When we run lmgrd, we've been bedeviled with error messages such as the one below indicating that the hostname in the license file is not a valid license server system host. We'll change the name to match and receive a similar message. We;re pulling our hair out.
MACSERVER:flexnetserver hughweisman$ sudo ./lmgrd -c /var/flexlm/adsk_server.lic14:00:05 (lmgrd) -----------------------------------------------
14:00:05 (lmgrd) Please Note:
14:00:05 (lmgrd) Server's System Date and Time: Thu May 08 2014 14:00:05 EDT
14:00:05 (lmgrd) SLOG: Summary LOG statistics is enabled.
14:00:05 (lmgrd) The license server manager (lmgrd) running as root:
14:00:05 (lmgrd) This is a potential security problem
14:00:05 (lmgrd) and is not recommended.
MACSERVER:flexnetserver hughweisman$ 14:00:06 (lmgrd) "MACSERVER": Not a valid server hostname, exiting.
14:00:06 (lmgrd) Valid license server system hosts are: "MACSERVER.local"
14:00:06 (lmgrd) Using license file "/var/flexlm/adsk_server.lic"
