I have a running version of the Autodesk Network License Manager from the Maya 2012 64Bit installer. On Windows Server 2008 R2.
However I need to move to support for IPv6. I have downloaded the installer from here and followed the readme file, but when I try to reread the license file it fails.
I have noticed that the IP address in the LMTool UI still has the IPv4 address not the IPv6 one as people tell me it should.
Has anyone encountered this before? If so what was the solution?
I have urgent need of a license on a machine that cannot communicate with IPv4. Please help ....
Tim
Thanks for the quick response.
Sadly it didn't help. I tried the ipv4 to ipv6 change on another machine and the new IP adress showed up fine.
What else could you suggest?
If you are using lmtools to control another product, check out the following post:
If you are still having a problem, can you send me personal email with your name/email? There is an envelope icon beside your handle beside (Sign Out).
