• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Expert Elite*
    TravisNave
    Accepted Solution
    Autodesk Network License Manager 2012
    21318 Views, 39 Replies
    03-23-2011 02:52 PM
    Well, it's that time again.  Time to update your Autodesk Network License Manager files to the latest and greatest (Autodesk) version.
    Autodesk is providing version 11.9 for 2012 products.
    You can get the Autodesk Network License Manager files here for both 32-bit and 64-bit versions:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10976858&linkID=9240698
    You can always get the latest version of the NLM from the following link:
    http://www.globes.com/support/fnp_utilities_download.htm
    At the time of this post, the latest version is 11.9.1.  I am attaching the necessary 32-bit adskflex vendor file in this message (v11.9.0.3) for your convenience
    You can update your license file to 2012 versions once your Subscription has been fulfilled.  You can do this via http://register.autodesk.com or by calling 1-800-551-1490.
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Autodesk Network License Manager 2012
    03-23-2011 02:57 PM in reply to: TravisNave
    For those of you using 64-bit systems, the appropriate adskflex vendor file is attached.  :smileyhappy:
    Travis Nave
    *Expert Elite*
    DarrenP
    03-23-2011 03:12 PM in reply to: TravisNave
    whats different between 11.9.0 & 11.9.1?
    *Expert Elite*
    TravisNave
    03-24-2011 09:04 AM in reply to: DarrenP
    I would suspect additional support for installation to virtual hosts and IPv6 compatibility.
    Travis Nave
    Distinguished Contributor
    05-18-2011 05:06 AM in reply to: TravisNave
    Download of the files from http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10976858&linkID=9240698 (as stated above) is blocked, as the gateway of one of our customers claim that these files are infected:
    "Gateway Anti-Virus Alert
    This request is blocked by the SonicWALL Gateway Anti-Virus Service. Name: (Cloud Id: 1000361) NewRest.BC (Trojan)"
    Can you please verify! I guess it is a fake alert, but you never know....
    *Expert Elite*
    DarrenP
    05-18-2011 05:45 AM in reply to: hans.martin.haga
    works fine here
    *Expert Elite*
    TravisNave
    05-18-2011 08:07 AM in reply to: hans.martin.haga
    I also verified all files a moment ago with my Symantec Web Gateway and the files came back as safe and malware free.  You may want to check your definitions as you are getting false positives.
    Travis Nave
    06-08-2011 01:05 PM in reply to: TravisNave
    Do you know where the 2012 License Manager files are located within the Autodesk download folders? I need to install remotely without the DVD in the server...would like to just copy the folder or executable. There is no longer a NLM folder.
    *Expert Elite*
    DarrenP
    06-08-2011 01:06 PM in reply to: MPeterman1
    what product?
    06-08-2011 01:25 PM in reply to: DarrenP
    Does not matter for product as you can install the license manager for anything. I have 2 different 2012 products downloaded...Autocad and Civil 3D, it looks like the installation package is very different than 2011. No NLM of NLM.MSI that I can find, not sure if this was repackaged.
