Just installed Mudbox 2011 32 bit version on my new laptop (Windows 7)
and for some reason it won't open at all.
The program starts running, for about a minute or so, and then I just get the dreaded:
Mudbox.exe application error: The instruction at 0x67053228 referenced memory at 0x00000010. The memory could not be written.
Please help me fix this!
Hi Adleder;
Are you still having troubles with this issue? Have you tried running the windows updates to see if there's anything on the system that can be updated? I would check to confirm that it's updated fully, check to see if there's any video driver updates and try again
Dwayne
Yes I updated everything and it worked.
However, the key that I purchased from a self-proclaimed partnered retailer was invalid. I reported the seller,returned the product, and uninstalled everything.
I'm dissapointed, to say the least, as it is very difficult to find a reasonably priced copy of Mudbox these days.
I just don't have $500-600 to spend on a program right now 😞
Sorry you had to return the application. You might try one of the resellers on the list below they might be able to help
http://usa.autodesk.com/adsk/servlet/partner/search?id=1088201&siteID=123112
Let me know if you need anything else
dwayne
Same problem...I just bought a DELL PRECISION 6600M with an NVIDIA 3000M. I click on the icon, after successfully installing everything, the software and my wacom Intuos 4...
I can see the Mudbox process run up to 10GB of processing (task bar), however nothing else happens. I tried repairing, uninstalling followed by a clean install still nothing...
Talk about frustration . Does anyone have an idea here? Please?
Kind Regards,
Ori
Hi Originor2382
Couple things I would check/try to fix this.
- update the graphics driver to the latest or qualified driver.
- update the wacom tablet drivers or uninstall them entirely to see if it's effecting. I've seen old drivers cause many issues with new 3d app
dwayne
