Installation & Licensing
New Member
mike.hf1337
Message 11 of 21 (1,996 Views)
Re: Autodesk Maya Student Serial Number Help
01-23-2013 02:39 PM in reply to: fluffysheep12345
Well, I chose to download the student version of 3ds Max 2011 and got the strange error "Error assigning serial number to product: This is an operation implementation generated fault".
But right under it there are my serial number and product key codes O.o
Well, I succesfully downloaded it, entered the code, installed and just when I tried to launch 3ds max 2011 it notified me to either register or use trial version for 30 days, well I chose to register ofc, and then it came with error saying that the serial number is not valid.
Also on the website in my account info, where it says "my sowftware" the number is 0. So, it's not registering or something.
Please help :smileysad:
philip.s
Message 12 of 21 (1,986 Views)
01-23-2013 04:23 PM in reply to: mike.hf1337
Hello Mike and our apologies for the inconvenience.
This is a known issue, affects a very limited amount of new registrations, that we're aware of and working on. As this is an account based problem that prevents your licensing information from functioning properly, the suggested workaround, would be to create a new Education Community profile with a different email address and request a new serial number.
Please let us know if this resolves the issue and or if you experience any further difficulties.
Philip Schmelzer
New Member
Message 13 of 21 (1,919 Views)
02-16-2013 10:11 AM in reply to: philip.s
I have downloaded AutoCAD and Mudbox successfully with no problems. But everytime i try to download studioMax (which I did) but everytime open the application I get this message from my Autodesk software:
But right under it there are my serial number and product key codes.
And everytime I try to add in these details it opens up with an error sign. Is there some way you can fix this?
Regards
Rozita
New Member
Message 14 of 21 (1,644 Views)
04-05-2013 11:01 AM in reply to: fluffysheep12345
I'm actually having the same problem when trying to download AutoCAD Civil 3D 2012 on his student's version.
"Error assigning serial number to product: This is an operation implementation generated fault". Then, I got a message above showing me a "standard" Product Key and Serial Number. They work great during the instalation process, but then, they result being invalid for activating definitely the product.
¿Where should I talk to someone to afford this issue? ¿There's a solution for this?
philip.s
Message 15 of 21 (1,603 Views)
04-05-2013 07:41 PM in reply to: cornalo.mario
My apologies for the inconvenience Mario.
We were experiencing in the Education Community earlier today which was not allowing users to select their school during the registration process and automatically associating Magenta Academy. In turn this caused certain products not to show up in the Download Center and an "Error assigning serial number to product: This is an operation implementation generated fault" message to display.
With that being said this has just been resolved and the site is once again fully functional. In order to access the site benefits, please create a new Education Community account using a different email address as your existing profile is corrupt, and request a new serial number.
Philip Schmelzer
New Member
Message 16 of 21 (1,592 Views)
04-06-2013 12:29 AM in reply to: philip.s
Philip, to be honest with you, I wasn't waiting for such an efficient answer in the short term. ¡Thanks a lot! Now, I've activated my AutoCAD Civil 3D 2012 with my own student's license.
Just to now, there's no way to completely eliminate my corrupted profile from the database?
That's because I'm using other products from Autodesk (Like Autodesk Homestyler), and I have them all registered under my gmail account. Actually, I had to use a hotmail account for AutoCAD, so I could generate a valid Serial Number. It'd be great to have this product registered under the same gmail account wich I use for daily mailing.
Thanks again for such an efficient support service.
Mario.
New Member
Message 17 of 21 (1,572 Views)
04-06-2013 10:48 AM in reply to: fluffysheep12345
Hello
I seem to be having the same exact problem with the serial number  Error assigning serial number to product: This is an operation implementation generated fault. It keeps saying that the serial number is invalid and to try again. I've been looking online for a solution but no luck. Sorry for the trouble but if someone could help with this that would be great.
Customer Service
joane.bonghanoy
Message 18 of 21 (1,548 Views)
04-07-2013 06:11 PM in reply to: eddygranda86
Hi eddygranda86,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code
Joane Bonghanoy
New Member
Message 19 of 21 (538 Views)
09-16-2013 01:17 PM in reply to: fluffysheep12345
Im haveing the exact same problem with my autocad download
philip.s
Message 20 of 21 (534 Views)
09-16-2013 01:37 PM in reply to: johncurran.ie
Welcome to the community John!
In this case, the error assigning serial number to product issue is typically caused by a backend profile issue, and is resolved by simply creating a new Education Community account with a new email address.
Can you let us know if that works for you?
Philip Schmelzer
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
