I have windows 7 64 bit but when i try to install student copy of maya i get autodesk maya 2015 failed and directconnect failed. i try download now and get connection error. if i do the browser install i get file is corrupt. how do i install maya on my machine?
Solved by jessica.t. Go to Solution.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
ok i went to the virtual agent to download maya but i get file not found for autodesk maya 2015 64bit.
Hi @Anonymous,
Apologies for the inconvenience, please try downloading from the Autodesk Maya 2015 Trial page. Thank you!
this is what i'm seeing in the log file Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/7:23:33:50 Alan Cook ALANCOOK-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
Hi @Anonymous,
Thanks for the details! Could you try this Autodesk Solution on the 1603 error and let me know if it resolves the issue? Thanks!
