• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    GeranBronn
    Autodesk Maya 2012 sp1 x64 installation failed
    1293 Views, 4 Replies
    02-07-2012 01:25 AM
    Hi I am trying to install Maya 2012 sp1 x64 But it keeps giving me this error.
    1:52:adlmPIT SetProductInformation failed 3:25
    And then in the installation log it gives me this:
    2012/2/7:10:53:58 Geran GERAN-PC === Setup started on GERAN-PC by Geran ===
    2012/2/7:10:53:58 Geran GERAN-PC Launch
    2012/2/7:10:54:25 Geran GERAN-PC PageOpen LaunchDialog
    2012/2/7:10:58:27 Geran GERAN-PC PageOpen LicenseDialog
    2012/2/7:11:03:32 Geran GERAN-PC PageOpen ProductInfoDialog
    2012/2/7:11:03:38 Geran GERAN-PC PageOpen ProductSelectionDialog2
    2012/2/7:11:03:40 Geran GERAN-PC PageOpen FullProgressDialog
    2012/2/7:11:03:40 Geran GERAN-PC Installing DirectX® Runtime: C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\DirectX\DXSETUP.exe /silent
    2012/2/7:11:06:39 Geran GERAN-PC Install DirectX® Runtime Succeeded
    2012/2/7:11:06:43 Geran GERAN-PC Installing Autodesk® Maya® 2012: TRANSFORMS="C:\Users\Geran\AppData\Local\Temp\_AI428.tmp\x64\Maya\Maya2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Maya_2012_EJ_Win_64-bit\" INSTALLDIR="C:\Program Files\Autodesk\Maya2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/2/7:11:15:12 Geran GERAN-PC Install Autodesk® Maya® 2012 Failed Installation aborted, Result=1603
    2012/2/7:11:15:12 Geran GERAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
    I am at my wits end! I have tried many possible solutions this is my final desparate attempt to get it working.
    If all else fails I will reinstall my Windows 7 (which I am not looking forward to)
    Please is there anyway around this error?
    All and any help will be much appreciated.
    Geran
    Please use plain text.
    Product Support
    Re: Autodesk Maya 2012 sp1 x64 installation failed
    02-07-2012 07:26 AM in reply to: GeranBronn
    Hi GeranBronn;
       Unfortunately the error indicates the Productinformation.PIT file has become corrupt. You will need to remove or rename the file to .OLD to install Maya. This will also force the re-installation of the other Autodesk applications. If you have other Autodesk applications please remove them via Add/Remove programs and then remove the .PIT from the below folder
    Windows XP
    C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM
    Windows Vista or 7
    C:\Users\All Users\Autodesk\Adlm
    - Note: you may need to turn on Show Hidden files and folders and Show System folders on in your control panel
    Dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    11-08-2012 03:08 AM in reply to: Dwayne.Poot
    Hello, I have a problem with the installation of Autodesk Maya 2012 . I installed the program many times but there seems to be some kind of a problem and I have this result=1603. Each time, there is this error while the Microsoft Visual C++ 2005 SP1 Redistributable installation. I dont know what to do, maybe someone can help me.
    Thank you.
    Windows 7
    Intel Core i7
    64bit OS
    video card : nvidia GeForce 660M
    New Member
    11-08-2012 08:59 AM in reply to: GeranBronn
    2012/10/26:01:52:55 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/26:01:52:55 LENOVO LENOVO-PC Launch
    2012/10/26:01:53:17 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:01:53:18 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/10/26:01:54:46 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/10/26:01:55:40 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/10/26:01:56:56 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/10/26:01:57:13 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/10/26:01:57:13 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/10/26:03:02:43 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    2012/10/26:03:02:43 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/10/26:07:08:43 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:07:10:44 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/26:07:10:44 LENOVO LENOVO-PC Launch
    2012/10/26:07:10:51 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:07:10:45 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/26:07:10:45 LENOVO LENOVO-PC Launch
    2012/10/26:07:10:51 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/10/26:07:14:21 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/10/26:07:15:39 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/10/26:07:16:41 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/10/26:07:18:18 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/10/26:07:18:19 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/10/26:08:42:02 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    2012/10/26:08:42:02 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/10/26:09:26:25 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:09:39:00 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/26:09:39:00 LENOVO LENOVO-PC Launch
    2012/10/26:09:39:08 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:09:39:07 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/10/26:09:40:37 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/10/26:09:41:02 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/10/26:09:41:33 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/10/26:09:41:39 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/10/26:09:41:39 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/10/26:10:52:26 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    2012/10/26:10:52:26 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/10/26:10:53:18 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:13:17:47 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/26:13:17:47 LENOVO LENOVO-PC Launch
    2012/10/26:13:17:59 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:13:17:48 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/26:13:17:48 LENOVO LENOVO-PC Launch
    2012/10/26:13:17:59 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/10/26:13:19:31 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/10/26:13:20:14 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/10/26:13:20:51 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/10/26:13:21:43 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/10/26:13:21:43 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/10/26:14:17:02 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    2012/10/26:14:17:02 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/10/26:16:49:44 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:16:54:06 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/26:16:54:06 LENOVO LENOVO-PC Launch
    2012/10/26:16:54:23 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:16:54:07 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/26:16:54:07 LENOVO LENOVO-PC Launch
    2012/10/26:16:54:23 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/10/26:16:54:27 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/10/26:16:54:30 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/10/26:16:54:56 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/10/26:16:54:56 LENOVO LENOVO-PC Installing Network License Manager: INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Maya_2012_EJ_Win_64-bit\" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/26:16:54:58 LENOVO LENOVO-PC Install Network License Manager Succeeded
    2012/10/26:16:54:58 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/10/26:16:55:09 LENOVO LENOVO-PC === Setup ended ===
    2012/10/26:16:56:07 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/26:16:56:07 LENOVO LENOVO-PC Launch
    2012/10/26:16:56:11 LENOVO LENOVO-PC === Setup ended ===
    2012/10/28:10:50:58 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/28:10:50:58 LENOVO LENOVO-PC Launch
    2012/10/28:10:51:13 LENOVO LENOVO-PC === Setup ended ===
    2012/10/28:10:51:00 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/28:10:51:00 LENOVO LENOVO-PC Launch
    2012/10/28:10:51:13 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/10/28:10:54:46 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/10/28:10:54:50 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/10/28:10:55:34 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/10/28:10:55:45 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/10/28:10:55:45 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): F:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/10/28:11:51:07 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    2012/10/28:11:51:08 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/10/28:12:14:28 LENOVO LENOVO-PC === Setup ended ===
    2012/10/31:15:24:52 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/31:15:24:52 LENOVO LENOVO-PC Launch
    2012/10/31:15:25:08 LENOVO LENOVO-PC === Setup ended ===
    2012/10/31:15:24:53 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/10/31:15:24:53 LENOVO LENOVO-PC Launch
    2012/10/31:15:25:09 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/10/31:15:26:33 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/10/31:15:27:09 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/10/31:15:27:43 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/10/31:15:29:38 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/10/31:15:29:38 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/10/31:16:24:58 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    2012/10/31:16:24:58 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/10/31:17:07:52 LENOVO LENOVO-PC === Setup ended ===
    2012/11/7:23:55:20 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/11/7:23:55:20 LENOVO LENOVO-PC Launch
    2012/11/7:23:55:44 LENOVO LENOVO-PC === Setup ended ===
    2012/11/7:23:55:21 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/11/7:23:55:21 LENOVO LENOVO-PC Launch
    2012/11/7:23:55:45 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/11/7:23:56:16 LENOVO LENOVO-PC PageOpen BeginDeploymentDialog
    2012/11/7:23:56:52 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/11/7:23:57:00 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/11/7:23:57:03 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/11/7:23:57:07 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/11/7:23:57:07 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/11/7:23:58:24 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/11/7:23:58:43 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/11/7:23:59:27 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/11/8:00:00:06 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/11/8:00:00:06 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/11/8:00:58:27 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    2012/11/8:00:58:27 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/11/8:01:09:50 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:01:12:07 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/11/8:01:12:07 LENOVO LENOVO-PC Launch
    2012/11/8:01:12:15 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:01:12:08 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/11/8:01:12:08 LENOVO LENOVO-PC Launch
    2012/11/8:01:12:15 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/11/8:01:16:13 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/11/8:01:16:32 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/11/8:01:16:58 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/11/8:01:17:02 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/11/8:01:17:02 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/11/8:03:08:56 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    2012/11/8:03:08:56 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/11/8:03:35:44 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:07:01:14 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/11/8:07:01:14 LENOVO LENOVO-PC Launch
    2012/11/8:07:01:28 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:07:01:28 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/11/8:07:03:00 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/11/8:07:04:32 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/11/8:07:05:16 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/11/8:07:05:20 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/11/8:07:05:21 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/11/8:08:00:39 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    2012/11/8:08:00:39 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
    2012/11/8:09:53:20 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:10:25:56 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/11/8:10:25:56 LENOVO LENOVO-PC Launch
    2012/11/8:10:26:55 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:10:26:55 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/11/8:10:28:16 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/11/8:10:28:34 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/11/8:10:29:16 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:10:29:37 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/11/8:10:29:37 LENOVO LENOVO-PC Launch
    2012/11/8:10:29:40 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:10:29:40 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/11/8:10:31:08 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/11/8:10:33:58 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:10:57:24 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/11/8:10:57:24 LENOVO LENOVO-PC Launch
    2012/11/8:10:57:28 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:13:16:42 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
    2012/11/8:13:16:42 LENOVO LENOVO-PC Launch
    2012/11/8:13:16:54 LENOVO LENOVO-PC === Setup ended ===
    2012/11/8:13:16:53 LENOVO LENOVO-PC PageOpen LaunchDialog
    2012/11/8:13:18:14 LENOVO LENOVO-PC PageOpen LicenseDialog
    2012/11/8:13:18:37 LENOVO LENOVO-PC PageOpen ProductInfoDialog
    2012/11/8:13:19:08 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
    2012/11/8:13:19:13 LENOVO LENOVO-PC PageOpen FullProgressDialog
    2012/11/8:13:19:13 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/11/8:15:05:33 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    How to fix that ...
    please help !!!
    New Member
    01-15-2013 11:56 AM in reply to: aleksandar930418
    Have same problem here, diffretns i my error is Result=2, and when i isntall only Maya, error give me massage
    "1606: COULD NOT ACCESS NETWORK LOCATION bin/DE-DE/"
    i tried instal and reinstall NET Framework, repair registry, also tried with disconected web but error always show
