Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Autodesk Maya 2012 sp1 x64 installati on failed
- Highlight
- Email to a Friend
Hi I am trying to install Maya 2012 sp1 x64 But it keeps giving me this error.
1:52:adlmPIT SetProductInformation failed 3:25
And then in the installation log it gives me this:
2012/2/7:10:53:58 Geran GERAN-PC === Setup started on GERAN-PC by Geran ===
2012/2/7:10:53:58 Geran GERAN-PC Launch
2012/2/7:10:54:25 Geran GERAN-PC PageOpen LaunchDialog
2012/2/7:10:58:27 Geran GERAN-PC PageOpen LicenseDialog
2012/2/7:11:03:32 Geran GERAN-PC PageOpen ProductInfoDialog
2012/2/7:11:03:38 Geran GERAN-PC PageOpen ProductSelectionDialog2
2012/2/7:11:03:40 Geran GERAN-PC PageOpen FullProgressDialog
2012/2/7:11:03:40 Geran GERAN-PC Installing DirectX® Runtime: C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\Direc
2012/2/7:11:06:39 Geran GERAN-PC Install DirectX® Runtime Succeeded
2012/2/7:11:06:43 Geran GERAN-PC Installing Autodesk® Maya® 2012: TRANSFORMS="C:\Users\Geran\AppData\Local\Temp\_AI4
2012/2/7:11:15:12 Geran GERAN-PC Install Autodesk® Maya® 2012 Failed Installation aborted, Result=1603
2012/2/7:11:15:12 Geran GERAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
I am at my wits end! I have tried many possible solutions this is my final desparate attempt to get it working.
If all else fails I will reinstall my Windows 7 (which I am not looking forward to)
Please is there anyway around this error?
All and any help will be much appreciated.
Geran
Re: Autodesk Maya 2012 sp1 x64 installati on failed
- Highlight
- Email to a Friend
Hi GeranBronn;
Unfortunately the error indicates the Productinformation.PIT file has become corrupt. You will need to remove or rename the file to .OLD to install Maya. This will also force the re-installation of the other Autodesk applications. If you have other Autodesk applications please remove them via Add/Remove programs and then remove the .PIT from the below folder
Windows XP
C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM
Windows Vista or 7
C:\Users\All Users\Autodesk\Adlm
- Note: you may need to turn on Show Hidden files and folders and Show System folders on in your control panel
Dwayne
Dwayne Poot
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hello, I have a problem with the installation of Autodesk Maya 2012 . I installed the program many times but there seems to be some kind of a problem and I have this result=1603. Each time, there is this error while the Microsoft Visual C++ 2005 SP1 Redistributable installation. I dont know what to do, maybe someone can help me.
Thank you.
Windows 7
Intel Core i7
64bit OS
video card : nvidia GeForce 660M
- Highlight
- Email to a Friend
2012/10/26:01:52:55 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:01:52:55 LENOVO LENOVO-PC Launch
2012/10/26:01:53:17 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:01:53:18 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:01:54:46 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:01:55:40 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/26:01:56:56 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:01:57:13 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:01:57:13 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\V
2012/10/26:03:02:43 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/26:03:02:43 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:07:08:43 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:07:10:44 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:07:10:44 LENOVO LENOVO-PC Launch
2012/10/26:07:10:51 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:07:10:45 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:07:10:45 LENOVO LENOVO-PC Launch
2012/10/26:07:10:51 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:07:14:21 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:07:15:39 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/26:07:16:41 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:07:18:18 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:07:18:19 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\V
2012/10/26:08:42:02 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/26:08:42:02 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:09:26:25 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:09:39:00 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:09:39:00 LENOVO LENOVO-PC Launch
2012/10/26:09:39:08 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:09:39:07 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:09:40:37 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:09:41:02 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/26:09:41:33 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:09:41:39 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:09:41:39 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\V
2012/10/26:10:52:26 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/26:10:52:26 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:10:53:18 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:13:17:47 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:13:17:47 LENOVO LENOVO-PC Launch
2012/10/26:13:17:59 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:13:17:48 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:13:17:48 LENOVO LENOVO-PC Launch
2012/10/26:13:17:59 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:13:19:31 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:13:20:14 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/26:13:20:51 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:13:21:43 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:13:21:43 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\V
2012/10/26:14:17:02 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/26:14:17:02 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:16:49:44 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:16:54:06 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:16:54:06 LENOVO LENOVO-PC Launch
2012/10/26:16:54:23 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:16:54:07 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:16:54:07 LENOVO LENOVO-PC Launch
2012/10/26:16:54:23 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:16:54:27 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:16:54:30 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:16:54:56 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:16:54:56 LENOVO LENOVO-PC Installing Network License Manager: INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Maya_2012_EJ_Win_64-
2012/10/26:16:54:58 LENOVO LENOVO-PC Install Network License Manager Succeeded
2012/10/26:16:54:58 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:16:55:09 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:16:56:07 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:16:56:07 LENOVO LENOVO-PC Launch
2012/10/26:16:56:11 LENOVO LENOVO-PC === Setup ended ===
2012/10/28:10:50:58 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/28:10:50:58 LENOVO LENOVO-PC Launch
2012/10/28:10:51:13 LENOVO LENOVO-PC === Setup ended ===
2012/10/28:10:51:00 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/28:10:51:00 LENOVO LENOVO-PC Launch
2012/10/28:10:51:13 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/28:10:54:46 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/28:10:54:50 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/28:10:55:34 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/28:10:55:45 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/28:10:55:45 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): F:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.e
2012/10/28:11:51:07 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/28:11:51:08 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/28:12:14:28 LENOVO LENOVO-PC === Setup ended ===
2012/10/31:15:24:52 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/31:15:24:52 LENOVO LENOVO-PC Launch
2012/10/31:15:25:08 LENOVO LENOVO-PC === Setup ended ===
2012/10/31:15:24:53 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/31:15:24:53 LENOVO LENOVO-PC Launch
2012/10/31:15:25:09 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/31:15:26:33 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/31:15:27:09 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/31:15:27:43 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/31:15:29:38 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/31:15:29:38 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\V
2012/10/31:16:24:58 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/31:16:24:58 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/31:17:07:52 LENOVO LENOVO-PC === Setup ended ===
2012/11/7:23:55:20 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/7:23:55:20 LENOVO LENOVO-PC Launch
2012/11/7:23:55:44 LENOVO LENOVO-PC === Setup ended ===
2012/11/7:23:55:21 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/7:23:55:21 LENOVO LENOVO-PC Launch
2012/11/7:23:55:45 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/7:23:56:16 LENOVO LENOVO-PC PageOpen BeginDeploymentDialog
2012/11/7:23:56:52 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/7:23:57:00 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/7:23:57:03 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/7:23:57:07 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/7:23:57:07 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/7:23:58:24 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/7:23:58:43 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/7:23:59:27 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/8:00:00:06 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/11/8:00:00:06 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\V
2012/11/8:00:58:27 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/11/8:00:58:27 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/11/8:01:09:50 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:01:12:07 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:01:12:07 LENOVO LENOVO-PC Launch
2012/11/8:01:12:15 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:01:12:08 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:01:12:08 LENOVO LENOVO-PC Launch
2012/11/8:01:12:15 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:01:16:13 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:01:16:32 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/8:01:16:58 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/8:01:17:02 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/11/8:01:17:02 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\V
2012/11/8:03:08:56 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/11/8:03:08:56 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/11/8:03:35:44 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:07:01:14 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:07:01:14 LENOVO LENOVO-PC Launch
2012/11/8:07:01:28 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:07:01:28 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:07:03:00 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:07:04:32 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/8:07:05:16 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/8:07:05:20 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/11/8:07:05:21 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\V
2012/11/8:08:00:39 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/11/8:08:00:39 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/11/8:09:53:20 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:25:56 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:10:25:56 LENOVO LENOVO-PC Launch
2012/11/8:10:26:55 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:26:55 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:10:28:16 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:10:28:34 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/8:10:29:16 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:29:37 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:10:29:37 LENOVO LENOVO-PC Launch
2012/11/8:10:29:40 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:29:40 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:10:31:08 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:10:33:58 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:57:24 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:10:57:24 LENOVO LENOVO-PC Launch
2012/11/8:10:57:28 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:13:16:42 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:13:16:42 LENOVO LENOVO-PC Launch
2012/11/8:13:16:54 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:13:16:53 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:13:18:14 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:13:18:37 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/8:13:19:08 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/8:13:19:13 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/11/8:13:19:13 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\V
2012/11/8:15:05:33 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
How to fix that ...
please help !!!
- Highlight
- Email to a Friend
Have same problem here, diffretns i my error is Result=2, and when i isntall only Maya, error give me massage
"1606: COULD NOT ACCESS NETWORK LOCATION bin/DE-DE/"
i tried instal and reinstall NET Framework, repair registry, also tried with disconected web but error always show
