Installation & Licensing
Autodesk Maya 2012 Unable to Install
1 REPLY 1
1710 Views, 1 Reply
Reader,
This is my problem. I am currently registered as a student, looking to use Maya for creating some character models. I am having this problem when installing, though:
I run the initial .exe, and unpack it to C:\Autodesk, and it unpacks the setup into there. I then run the setup, and hit install, accept the agreement, put in my activation code, and then hit install, changing nothing, and keeping all the checked installations checked. It either does one of the two: It shows the bar moving for a split second, then errors with
2012/1/14:21:32:00 Patrick PATRICK-PC === Setup started on PATRICK-PC by Patrick ===
2012/1/14:21:32:00 Patrick PATRICK-PC Launch
2012/1/14:21:32:21 Patrick PATRICK-PC PageOpen LaunchDialog
2012/1/14:21:34:44 Patrick PATRICK-PC PageOpen LicenseDialog
2012/1/14:21:34:55 Patrick PATRICK-PC PageOpen ProductInfoDialog
2012/1/14:21:35:05 Patrick PATRICK-PC PageOpen ProductSelectionDialog2
2012/1/14:21:35:09 Patrick PATRICK-PC PageOpen FullProgressDialog
2012/1/14:21:35:09 Patrick PATRICK-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Patrick\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/1/14:21:35:11 Patrick PATRICK-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/1/14:21:35:12 Patrick PATRICK-PC PageOpen InstallCompleteDialog
2012/1/14:21:35:17 Patrick PATRICK-PC === Setup ended ===
OR It will continue to go through the moving bar, then it will stop at what seems to be 99%, and just do nothing after that. It doesn't freeze nor crash, but just stops, and just sits there aimlessly. After that I have to terminate the process.
I know it has to do with the Microsoft Visual C++ 2005 installations, but I don't know how to fix this issue.
I am currently running from a laptop, which to the best of my knowledge contains an i3 processer, (unkown graphics, if you know how to find out, do tell.), 3.80gb RAM, 500gb HDD (270gb free). If you need more information to come to a conculusion, do tell. I would like to have this fixed so I can download this. It has also happened with other programs that try to do anything with MVC++, as in, it won't download and it just crashes.
Thanks for you time,
--RD
1 REPLY 1
hashim.mundol
Please try
http://forums.autodesk.com/t5/Installation-Licensing/Installation-Errors-for-Revit/td-p/3030072
http://forums.autodesk.com/t5/Installation-Licensing/Revit-2012-Install-failed/td-p/3008792
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Administrator Productivity
