I have a problem to start my Inventor 2014.
I have downloaded the professional version from students server and instaled it wisout isues.
But when i try to lounch the program i got that small white window :
I tryed to found a solution in other forum and with google, but nothing worked
I run a windows 7 64 pro
Someone can help me please?
Solved by Blanchardlo. Go to Solution.
Solved by asburyj. Go to Solution.
Hi Blanchardlo,
Can you let me know what version of internet exlorer is installed on your system? Also, what troubleshooting steps have you tried already?
hello, thanks for your reply.
I have IE 10 but i'm doing update.
I firstly tried to re-instal
next i've checked that my activX is set up
next i'hv checked my registry for internet option, where all was set to 0 as needed for ActiveX
I've tryed to set all process to admin right
I started windows in safe mode with network, but Inventor just crashed then
An i've open the script of the licence window (from tmp file) and i tryed to find the problem.
It seem tha the function "startani()" is not reconized by my computer.
In some cases we have seen IE 10 lead to trouble at product launch
Let's try uninstalling IE 10 and reverting back to IE 9 as a test to see if this could be the situiation for you as well.
There is a guide on uninstalling IE 10 in the below forum post, look for "option three"
http://www.sevenforums.com/tutorials/282216-internet-explorer-10-install-uninstall-windows-7-a.html
