I have been tasked with installing Autodesk on one computer in our network (It is a Network installation). I have installed some Autodesk (2012) products on the PC; however I am experiencing a problem with Autodesk Fusion. The installation terminates successfully, however when I double click on the icon to run it, the application starts and shortly produces an error message. A screen shot of the error is attached. Could you please advise?
Solved by dtsc1. Go to Solution.
it tells you what the problem is
its your graphics card or the driver
DarrenP
