Installation & Licensing
harihars
396 Views, 4 Replies
Autodesk Inventor 2014
Hi !
I am trying to install Autodesk Inventor 2014 on my Windows 8.1 Machine, but after browser download when I try to install it, I get the following error:
I was able to install Inventor 2013, but I was not able to run it on Windows 8.1 ..
Please advice.
Thank you for your support!
Tags (1)
4 REPLIES 4
TravisNave
in reply to: harihars
Welcome to the community.
Try downloading it from the virtual assistant.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
harihars
in reply to: TravisNave
Thank you for your response. I downloaded the two parts into a single folder. When I run the exe, it opens the Auto-Desk Self Extract and after about 8Gb of extraction, it just stops.. the progress bar shows 1 minute remaining, but nothing happens. Please advice the correct steps for intallation.
Product to be installed: Autodesk Inventor
OS: Windows 8.1 64bit
Thank you for your support.
--Hari
dgorsman
I believe Inventor 2014 requires some additional patches to run under Win 8.1.  For certain, earlier versions do.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
harihars
in reply to: dgorsman
I downloaded a service pack that I need to install after installing the product, but I am unable to find any patch that needs to be installed prior to installing inventor. And the installation fails in the extraction process itself.
Please advice.
Administrator Productivity
