Installation & Licensing
New Member
clwi
Message 1 of 1 (186 Views)
Autodesk Inventor 2013 SP 1.1 Problem with Autodesk Sync
186 Views, 0 Replies
03-26-2013 01:14 AM
Recently I got the Autodesk Inventor 2013 x64 installed and updated with Service Pack 1.1 and noticed an issue regarding the Autodesk Sync.
The problem is that during the installation of the patch(using msiexec.exe /P <patchfile>.msp) it writes to the registry HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Autodesk Sync\InstalledProducts a secondary "Inventor 2013" without any semicolon seperator or anything else(see attatchment). This results in that when/if Inventor 2013 is uninstalled an instance of "Inventor 2013" is still present in the registry and prevents you from uninstalling the Autodesk Sync application, even though there are no products left on the machine that are dependant on the application.
Removing the registry key mentioned above resolves the issue and you are able to uninstall Autodesk Sync, but this is not an approach that is very appealing since it involves a risk of uninstalling Autodesk Sync when there's still other products installed.
A solution would be an updated version of the Service Pack 1.1 to resolve the issue caused by it in the first place.
Best Regards
Claes Wikemar
AEC AB
Gothenburg Sweden
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
