Installation & Licensing
New Member
rodgerkeesee
Message 1 of 2 (262 Views)
Autodesk Inventor 2013 100% CPU on new OS install - SOLVED
262 Views, 1 Replies
06-24-2013 10:22 PM
Posting this here in case anyone else has this problem. I installed Autodesk Product Development Suite 2013 on a freshly unboxed Dell Precision M4700 (plenty of horsepower). Autodesk Inventor ran extremely slowly and took 100% of one CPU core, or around 30% of the total CPU. The other Autodesk apps in the suite ran quick and smooth.
Lot's of troubleshooting later - the fix is to NOT use a custom font scaling in the OS. Once I changed the display text size to Medium 125% (the default) the problem was resolved.
Hopefully this note means you won't have to go through what I did, but here's the deets if you care: I set up my new hi-res laptop with Windows 8 and thought the default system font size of Medium 125% was too big so I changed it to 110%. Then i proceeded to install all my software on the laptop. Inventor barely ran on the new laptop and was way faster on my 3 year old laptop so I knew something was wrong. I ran Process Monitor from SysInternals and it showed that Inventor was getting a Buffer Overflow error on a particular font. The error occurred repeatedly and was causing an endless loop. I uninstalled that font and when I rebooted my system font was replaced by some weird font. So that's when I discovered the problem was related to the system font. And once I knew that the problem was fixed in minutes. This all took place over about 6 hours of multiple full uninstalls, test profiles, changing permissions, registry investigations, etc.
TravisNave
Message 2 of 2 (245 Views)
Re: Autodesk Inventor 2013 100% CPU on new OS install - SOLVED
06-26-2013 10:07 AM in reply to: rodgerkeesee
Thanks for sharing and adding to the value of the community.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
