Installation & Licensing
New Member
amurphy56
Message 1 of 7 (4,835 Views)
Autodesk Inventor 2012 Installation errors
4835 Views, 6 Replies
12-25-2011 01:21 AM
Hi, I am trying to install Autodesk Inventor 2012 hoewver the install keeps failing. The software will attempt to install and promptly end, saying, " Installation complete. Some products failed to install." There are X's on everything and Failed beside Autodesk Design Review 2012.
My system:
Fresh Install of Windows 7, 8GB Ram, 1TB HD, Updates all complete.
Any help would be greatly appreciated as Im not sure where to start.
The error Log:
=== Setup started on DESKTOP-HP by desktop === 2011/12/20:19:05:10 desktop DESKTOP-HP Launch 2011/12/20:19:06:02 desktop DESKTOP-HP === Setup ended ===
2011/12/20:19:05:11 desktop DESKTOP-HP === Setup started on DESKTOP-HP by desktop === 2011/12/20:19:05:11 desktop DESKTOP-HP Launch 2011/12/20:19:05:16 desktop DESKTOP-HP Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/20:19:05:17 desktop DESKTOP-HP Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2011/12/20:19:05:17 desktop DESKTOP-HP Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2011/12/20:19:06:01 desktop DESKTOP-HP Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/20:19:06:03 desktop DESKTOP-HP PageOpen LaunchDialog   2011/12/20:19:07:51 desktop DESKTOP-HP PageOpen LicenseDialog   2011/12/20:19:12:00 desktop DESKTOP-HP PageOpen ProductInfoDialog   2011/12/20:19:13:16 desktop DESKTOP-HP PageOpen InventorFlavorSelectionDialog   2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==DefaultLanguage: en-us    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==InstallName: INVENTOR    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==ProductName: Autodesk Inventor 2012    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==DisplayName: Autodesk® Inventor® 2012    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==DeploymentName:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==SetupTitle: Autodesk Inventor 2012    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==ConfigTransform:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==ExeParams:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==SupportLink:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==InfotainmentLink:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==MsiFileName: inventor.msi    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==AdminImageConfigName: AdminImagex64    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==AdminImageRoot:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==GetBaseDeploymentName:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==DeploymentLocation:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==InstallDeploymentShortcut:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==ModifyDeploymentShortcut:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==SetupLockType: 2    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==SetupNetworkType:  0    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==SystemLocale: 4105    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==EvalMsiFilePath: C:\Users\desktop\AppData\Local\Temp\_AIA2B5.tmp\SetupRes\eval.msi    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==EulaPath: C:\Users\desktop\AppData\Local\Temp\_AIA2B5.tmp\EULA    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==InstallLogPath: C:\Users\desktop\AppData\Local\Temp\Inventor2012Install.log    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==ConfigFile: C:\Users\desktop\AppData\Local\Temp\_AIA2B5.tmp\Setup.ini    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==NetworkLogPath:     2011/12/20:19:13:16 desktop DESKTOP-HP Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/20:19:13:21 desktop DESKTOP-HP Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2011/12/20:19:13:21 desktop DESKTOP-HP PageOpen ProductSelectionDialog2   2011/12/20:19:13:53 desktop DESKTOP-HP PageOpen FullProgressDialog   2011/12/20:19:13:53 desktop DESKTOP-HP Installing Microsoft Visual C++ 2005 SP1 (x86):   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/12/20:19:14:09 desktop DESKTOP-HP Install Microsoft Visual C++ 2005 SP1 (x86) Succeeded  2011/12/20:19:14:09 desktop DESKTOP-HP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\desktop\AppData\Local\Temp\vcredist_x86_2010.log 2011/12/20:19:14:13 desktop DESKTOP-HP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2011/12/20:19:14:13 desktop DESKTOP-HP PageOpen InstallCompleteDialog   2011/12/20:19:16:25 desktop DESKTOP-HP === Setup ended ===
2011/12/20:20:11:29 desktop DESKTOP-HP === Setup started on DESKTOP-HP by desktop === 2011/12/20:20:11:29 desktop DESKTOP-HP Launch 2011/12/20:20:12:08 desktop DESKTOP-HP === Setup ended ===
2011/12/20:20:11:30 desktop DESKTOP-HP === Setup started on DESKTOP-HP by desktop === 2011/12/20:20:11:30 desktop DESKTOP-HP Launch 2011/12/20:20:11:36 desktop DESKTOP-HP Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/20:20:11:36 desktop DESKTOP-HP Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2011/12/20:20:11:36 desktop DESKTOP-HP Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2011/12/20:20:12:08 desktop DESKTOP-HP Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/20:20:12:08 desktop DESKTOP-HP PageOpen LaunchDialog   2011/12/20:20:12:27 desktop DESKTOP-HP PageOpen LicenseDialog   2011/12/20:20:12:43 desktop DESKTOP-HP PageOpen ProductInfoDialog   2011/12/20:20:13:16 desktop DESKTOP-HP PageOpen InventorFlavorSelectionDialog   2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==DefaultLanguage: en-us    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==InstallName: INVENTOR    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==ProductName: Autodesk Inventor 2012    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==DisplayName: Autodesk® Inventor® 2012    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==DeploymentName:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==SetupTitle: Autodesk Inventor 2012    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==ConfigTransform:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==ExeParams:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==SupportLink:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==InfotainmentLink:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==MsiFileName: inventor.msi    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==AdminImageConfigName: AdminImagex64    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==AdminImageRoot:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==GetBaseDeploymentName:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==DeploymentLocation:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==InstallDeploymentShortcut:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==ModifyDeploymentShortcut:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==SetupLockType: 2    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==SetupNetworkType:  0    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==SystemLocale: 4105    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==EvalMsiFilePath: C:\Users\desktop\AppData\Local\Temp\_AI5A13.tmp\SetupRes\eval.msi    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==EulaPath: C:\Users\desktop\AppData\Local\Temp\_AI5A13.tmp\EULA    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==InstallLogPath: C:\Users\desktop\AppData\Local\Temp\Inventor2012Install.log    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==ConfigFile: C:\Users\desktop\AppData\Local\Temp\_AI5A13.tmp\Setup.ini    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==NetworkLogPath:     2011/12/20:20:13:16 desktop DESKTOP-HP Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/20:20:13:20 desktop DESKTOP-HP Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2011/12/20:20:13:20 desktop DESKTOP-HP PageOpen ProductSelectionDialog2   2011/12/20:20:13:32 desktop DESKTOP-HP PageOpen FullProgressDialog   2011/12/20:20:13:32 desktop DESKTOP-HP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\desktop\AppData\Local\Temp\vcredist_x86_2010.log 2011/12/20:20:13:35 desktop DESKTOP-HP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2011/12/20:20:13:35 desktop DESKTOP-HP PageOpen InstallCompleteDialog   2011/12/22:17:28:57 desktop DESKTOP-HP === Setup ended ===
2011/12/22:17:50:25 desktop DESKTOP-HP === Setup started on DESKTOP-HP by desktop === 2011/12/22:17:50:25 desktop DESKTOP-HP Launch 2011/12/22:17:51:11 desktop DESKTOP-HP === Setup ended ===
2011/12/22:17:50:26 desktop DESKTOP-HP === Setup started on DESKTOP-HP by desktop === 2011/12/22:17:50:26 desktop DESKTOP-HP Launch 2011/12/22:17:50:30 desktop DESKTOP-HP Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/22:17:50:31 desktop DESKTOP-HP Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2011/12/22:17:50:31 desktop DESKTOP-HP Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2011/12/22:17:51:10 desktop DESKTOP-HP Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/22:17:51:11 desktop DESKTOP-HP PageOpen LaunchDialog   2011/12/22:17:51:18 desktop DESKTOP-HP Inventorui== Parameter: Prereq_8 SetupMode:7 InstallState:1 InstallAction:0 Message: 2011/12/22:17:51:18 desktop DESKTOP-HP PageOpen LicenseDialog   2011/12/22:17:51:31 desktop DESKTOP-HP PageOpen ProductSelectionDialog2   2011/12/22:17:51:36 desktop DESKTOP-HP PageOpen LicenseDialog   2011/12/22:17:51:37 desktop DESKTOP-HP PageOpen LaunchDialog   2011/12/22:17:51:55 desktop DESKTOP-HP PageOpen LicenseDialog   2011/12/22:17:52:23 desktop DESKTOP-HP PageOpen ProductInfoDialog   2011/12/22:17:53:14 desktop DESKTOP-HP PageOpen InventorFlavorSelectionDialog   2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==DefaultLanguage: en-us    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==InstallName: INVENTOR    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==ProductName: Autodesk Inventor 2012    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==DisplayName: Autodesk® Inventor® 2012    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==DeploymentName:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==SetupTitle: Autodesk Inventor 2012    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==ConfigTransform:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==ExeParams:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==SupportLink:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==InfotainmentLink:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==MsiFileName: inventor.msi    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==AdminImageConfigName: AdminImagex64    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==AdminImageRoot:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==GetBaseDeploymentName:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==DeploymentLocation:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==InstallDeploymentShortcut:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==ModifyDeploymentShortcut:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==SetupLockType: 2    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==SetupNetworkType:  0    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==SystemLocale: 4105    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==EvalMsiFilePath: C:\Users\desktop\AppData\Local\Temp\_AIEF1F.tmp\SetupRes\eval.msi    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==EulaPath: C:\Users\desktop\AppData\Local\Temp\_AIEF1F.tmp\EULA    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==InstallLogPath: C:\Users\desktop\AppData\Local\Temp\Inventor2012Install.log    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==ConfigFile: C:\Users\desktop\AppData\Local\Temp\_AIEF1F.tmp\Setup.ini    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==NetworkLogPath:     2011/12/22:17:53:14 desktop DESKTOP-HP Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/22:17:53:17 desktop DESKTOP-HP Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2011/12/22:17:53:17 desktop DESKTOP-HP PageOpen ProductSelectionDialog2   2011/12/22:17:54:21 desktop DESKTOP-HP Inventorui== Parameter: Page3 Action: SetMsiProperty Item: ALLOWDRAWINGEDIT Value:1 2011/12/22:17:54:21 desktop DESKTOP-HP Inventorui== Parameter: Page3 Action: SetMsiProperty Item: ALLOWDRAWINGEDIT_UI Value:Enabled 2011/12/22:17:54:21 desktop DESKTOP-HP Inventorui== Parameter: Page3 Action: SetMsiProperty Item: UNITS Value:INCH 2011/12/22:17:54:21 desktop DESKTOP-HP Inventorui== Parameter: Page3 Action: SetProperty Item: MSIPROPERTY_DRAWINGSTANDARD Value:ANSI 2011/12/22:17:54:21 desktop DESKTOP-HP Inventorui== Parameter: Page3 Action: SetProperty Item: INSTALLPROFILE Value:1 2011/12/22:17:54:21 desktop DESKTOP-HP Inventorui== Parameter: Page3 Action: SetMsiProperty Item: INSTALLPROFILE_UI Value:smileyvery-happy:efault Inventor settings 2011/12/22:17:54:21 desktop DESKTOP-HP Inventorui== Parameter: Page1 Action: SetProperty Item: INSTALLVAULTSERVERCC Value:0 2011/12/22:17:54:21 desktop DESKTOP-HP Inventorui== Parameter: Page1 Action: SetMsiProperty Item: DCACCESSOPTION Value:Inventor Desktop Content 2011/12/22:17:54:53 desktop DESKTOP-HP PageOpen FullProgressDialog   2011/12/22:17:54:53 desktop DESKTOP-HP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\desktop\AppData\Local\Temp\vcredist_x86_2010.log 2011/12/22:17:54:56 desktop DESKTOP-HP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2011/12/22:17:54:57 desktop DESKTOP-HP PageOpen InstallCompleteDialog   2011/12/22:17:59:27 desktop DESKTOP-HP === Setup ended ===
2011/12/22:18:06:20 desktop DESKTOP-HP === Setup started on DESKTOP-HP by desktop === 2011/12/22:18:06:20 desktop DESKTOP-HP Launch 2011/12/22:18:06:31 desktop DESKTOP-HP === Setup ended ===
2011/12/22:18:06:21 desktop DESKTOP-HP === Setup started on DESKTOP-HP by desktop === 2011/12/22:18:06:21 desktop DESKTOP-HP Launch 2011/12/22:18:06:24 desktop DESKTOP-HP Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/22:18:06:24 desktop DESKTOP-HP Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2011/12/22:18:06:24 desktop DESKTOP-HP Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2011/12/22:18:06:31 desktop DESKTOP-HP Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/22:18:06:31 desktop DESKTOP-HP PageOpen LaunchDialog   2011/12/22:18:11:43 desktop DESKTOP-HP PageOpen LicenseDialog   2011/12/22:18:11:53 desktop DESKTOP-HP PageOpen ProductInfoDialog   2011/12/22:18:12:18 desktop DESKTOP-HP PageOpen InventorFlavorSelectionDialog   2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==DefaultLanguage: en-us    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==InstallName: INVENTOR    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==ProductName: Autodesk Inventor 2012    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==DisplayName: Autodesk® Inventor® 2012    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==DeploymentName:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==SetupTitle: Autodesk Inventor 2012    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==ConfigTransform:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==ExeParams:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==SupportLink:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==InfotainmentLink:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==MsiFileName: inventor.msi    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==AdminImageConfigName: AdminImagex64    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==AdminImageRoot:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==GetBaseDeploymentName:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==DeploymentLocation:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==InstallDeploymentShortcut:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==ModifyDeploymentShortcut:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==SetupLockType: 2    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==SetupNetworkType:  0    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==SystemLocale: 4105    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==EvalMsiFilePath: C:\Users\desktop\AppData\Local\Temp\_AI8333.tmp\SetupRes\eval.msi    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==EulaPath: C:\Users\desktop\AppData\Local\Temp\_AI8333.tmp\EULA    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==InstallLogPath: C:\Users\desktop\AppData\Local\Temp\Inventor2012Install.log    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==ConfigFile: C:\Users\desktop\AppData\Local\Temp\_AI8333.tmp\Setup.ini    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==NetworkLogPath:     2011/12/22:18:12:18 desktop DESKTOP-HP Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/22:18:12:21 desktop DESKTOP-HP Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2011/12/22:18:12:21 desktop DESKTOP-HP PageOpen ProductSelectionDialog2   2011/12/22:18:12:42 desktop DESKTOP-HP PageOpen FullProgressDialog   2011/12/22:18:12:43 desktop DESKTOP-HP Installing VBA Runtime:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/12/22:18:12:43 desktop DESKTOP-HP Install VBA Runtime Failed Failure is ignored, Result=1601 2011/12/22:18:12:43 desktop DESKTOP-HP Installing DirectX® Runtime: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2011/12/22:18:12:52 desktop DESKTOP-HP Install DirectX® Runtime Succeeded  2011/12/22:18:12:52 desktop DESKTOP-HP Installing Web Services Enhancements (WSE) 3.0 for Microsoft .NET:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/12/22:18:12:52 desktop DESKTOP-HP Install Web Services Enhancements (WSE) 3.0 for Microsoft .NET Failed Installation aborted, Result=1601 2011/12/22:18:12:52 desktop DESKTOP-HP Rollback DirectX® Runtime Failed Failure is ignored, Result=1601 2011/12/22:18:12:53 desktop DESKTOP-HP PageOpen InstallCompleteDialog   2011/12/22:18:23:01 desktop DESKTOP-HP === Setup ended ===
2011/12/25:02:38:32 desktop DESKTOP-HP === Setup started on DESKTOP-HP by desktop === 2011/12/25:02:38:32 desktop DESKTOP-HP Launch 2011/12/25:02:39:20 desktop DESKTOP-HP === Setup ended ===
2011/12/25:02:38:33 desktop DESKTOP-HP === Setup started on DESKTOP-HP by desktop === 2011/12/25:02:38:33 desktop DESKTOP-HP Launch 2011/12/25:02:38:37 desktop DESKTOP-HP Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/25:02:38:38 desktop DESKTOP-HP Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2011/12/25:02:38:38 desktop DESKTOP-HP Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2011/12/25:02:39:19 desktop DESKTOP-HP Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2011/12/25:02:39:21 desktop DESKTOP-HP PageOpen LaunchDialog   2011/12/25:02:53:47 desktop DESKTOP-HP PageOpen LicenseDialog   2011/12/25:02:54:06 desktop DESKTOP-HP PageOpen ProductInfoDialog   2011/12/25:02:54:47 desktop DESKTOP-HP PageOpen InventorFlavorSelectionDialog   2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==DefaultLanguage: en-us    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==InstallName: INVENTOR    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==ProductName: Autodesk Inventor 2012    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==DisplayName: Autodesk® Inventor® 2012    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==DeploymentName:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==SetupTitle: Autodesk Inventor 2012    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==ConfigTransform:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==ExeParams:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==SupportLink:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==InfotainmentLink:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==MsiFileName: inventor.msi    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==AdminImageConfigName: AdminImagex64    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==AdminImageRoot:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==GetBaseDeploymentName:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==DeploymentLocation:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==InstallDeploymentShortcut:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==ModifyDeploymentShortcut:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==SetupLockType: 2    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==SetupNetworkType:  0    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==SystemLocale: 4105    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==EvalMsiFilePath: C:\Users\desktop\AppData\Local\Temp\_AIACCB.tmp\SetupRes\eval.msi    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==EulaPath: C:\Users\desktop\AppData\Local\Temp\_AIACCB.tmp\EULA    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==InstallLogPath: C:\Users\desktop\AppData\Local\Temp\Inventor2012Install.log    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==ConfigFile: C:\Users\desktop\AppData\Local\Temp\_AIACCB.tmp\Setup.ini    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==NetworkLogPath:     2011/12/25:02:54:47 desktop DESKTOP-HP Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\    2011/12/25:02:54:49 desktop DESKTOP-HP Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2011/12/25:02:54:49 desktop DESKTOP-HP PageOpen ProductSelectionDialog2   2011/12/25:02:54:58 desktop DESKTOP-HP PageOpen FullProgressDialog   2011/12/25:02:54:58 desktop DESKTOP-HP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\desktop\AppData\Local\Temp\vcredist_x86_2010.log 2011/12/25:02:55:01 desktop DESKTOP-HP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Product Support
emily.xu
Message 2 of 7 (4,795 Views)
Re: Autodesk Inventor 2012 Installation errors
12-26-2011 11:04 PM in reply to: amurphy56
I can see the error at the end of log: Install Mic​rosoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603, could you please try to install it manually? Find it under the folder: \3rdParty\x86\VCRedist\2010, after successful install VC++, then try to reinstall inventor 2012.
Hope helps!
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
New Member
kintera
Message 3 of 7 (4,781 Views)
12-27-2011 08:41 AM in reply to: amurphy56
I am getting the same error and have attempted to intall the redistrutable from the folder on the system and the istaller for visual c++ 2010 states: "can't install newer version already installed" and will not all me to install this software.
fresh install as well just ran windows update.
New Member
kintera
Message 4 of 7 (4,769 Views)
12-27-2011 10:35 AM in reply to: kintera
Ok to get past this I attempted putting a newer version of the redistbutable in the install folder that doesn't work sadly.
this issue seems to come from windows updating Visual C++ 2010 and thus the file in this installer is unable to detect its properly installed and attempting to update something that is already updated. Thus the installer in the redistrutable throws an error and breaks the installer. The Hotfix - Autodesk Design Review 2012 does not fix this bug.
In order to get around this in Windows 7
1. Goto Control Panel > Programs and Features
2. then uninstall any version of the Visual C++ 2010 you may have. (This procedure may require a few reboots.)
once you have confirmed all as nothing shows up in the programs and features
3. Install your Autodesk product as you normally would and it should work.
Workaround by:
Kasey Norman
Robotics and Embedded System student
at the University of Advancing Technology
Product Support
emily.xu
Message 5 of 7 (4,751 Views)
12-27-2011 05:12 PM in reply to: kintera
Thanks for sharing the tips!
Emily Xu
New Member
jbuckland
Message 6 of 7 (3,829 Views)
07-12-2012 03:31 AM in reply to: kintera
Thanks kintera!
I was having the same problem with my copy of inventor and your solution worked perfectly.
Now to finally work on my assignment!
Active Member
best_industry
Message 7 of 7 (3,017 Views)
11-28-2012 11:09 AM in reply to: amurphy56
Hi, I have a problem install Autodesk Inventor 2012 Student Version. Below is the installation log file:
2012/11/29:01:32:03 Mark MARK-PC === Setup started on MARK-PC by Mark ===
2012/11/29:01:32:03 Mark MARK-PC Launch
2012/11/29:01:32:33 Mark MARK-PC === Setup ended ===
2012/11/29:01:32:04 Mark MARK-PC === Setup started on MARK-PC by Mark ===
2012/11/29:01:32:04 Mark MARK-PC Launch
2012/11/29:01:32:18 Mark MARK-PC Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/11/29:01:32:22 Mark MARK-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/11/29:01:32:22 Mark MARK-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/11/29:01:32:29 Mark MARK-PC PageOpen LaunchDialog
2012/11/29:01:34:25 Mark MARK-PC PageOpen LicenseDialog
2012/11/29:01:38:10 Mark MARK-PC PageOpen ProductInfoDialog
2012/11/29:01:43:22 Mark MARK-PC PageOpen InventorFlavorSelectionDialog
2012/11/29:01:43:22 Mark MARK-PC Inventorui==DefaultLanguage: en-us
2012/11/29:01:43:22 Mark MARK-PC Inventorui==InstallName: INVENTOR
2012/11/29:01:43:22 Mark MARK-PC Inventorui==ProductName: Autodesk Inventor 2012
2012/11/29:01:43:22 Mark MARK-PC Inventorui==DisplayName: Autodesk® Inventor® 2012
2012/11/29:01:43:22 Mark MARK-PC Inventorui==DeploymentName:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==SetupTitle: Autodesk Inventor 2012
2012/11/29:01:43:22 Mark MARK-PC Inventorui==ConfigTransform:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==ExeParams:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/11/29:01:43:22 Mark MARK-PC Inventorui==SupportLink:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==InfotainmentLink:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==MsiFileName: inventor.msi
2012/11/29:01:43:22 Mark MARK-PC Inventorui==AdminImageConfigName: AdminImagex64
2012/11/29:01:43:22 Mark MARK-PC Inventorui==AdminImageRoot:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==GetBaseDeploymentName:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==DeploymentLocation:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2012/11/29:01:43:22 Mark MARK-PC Inventorui==InstallDeploymentShortcut:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==ModifyDeploymentShortcut:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==SetupLockType: 2
2012/11/29:01:43:22 Mark MARK-PC Inventorui==SetupNetworkType: 0
2012/11/29:01:43:22 Mark MARK-PC Inventorui==SystemLocale: 18441
2012/11/29:01:43:22 Mark MARK-PC Inventorui==EvalMsiFilePath: C:\Users\Mark\AppData\Local\Temp\_AI3278.tmp\SetupRes\eval.msi
2012/11/29:01:43:22 Mark MARK-PC Inventorui==EulaPath: C:\Users\Mark\AppData\Local\Temp\_AI3278.tmp\EULA
2012/11/29:01:43:22 Mark MARK-PC Inventorui==InstallLogPath: C:\Users\Mark\AppData\Local\Temp\Inventor2012Install.log
2012/11/29:01:43:22 Mark MARK-PC Inventorui==ConfigFile: C:\Users\Mark\AppData\Local\Temp\_AI3278.tmp\Setup.ini
2012/11/29:01:43:22 Mark MARK-PC Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:01:43:22 Mark MARK-PC Inventorui==NetworkLogPath:
2012/11/29:01:43:22 Mark MARK-PC Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:01:43:28 Mark MARK-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/11/29:01:43:28 Mark MARK-PC PageOpen ProductSelectionDialog2
2012/11/29:01:44:02 Mark MARK-PC PageOpen FullProgressDialog
2012/11/29:01:44:02 Mark MARK-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Mark\AppData\Local\Temp\vcredist_x86_2010.log
2012/11/29:01:44:05 Mark MARK-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/11/29:01:44:06 Mark MARK-PC PageOpen InstallCompleteDialog
2012/11/29:01:44:19 Mark MARK-PC === Setup ended ===
2012/11/29:01:57:56 Mark MARK-PC === Setup started on MARK-PC by Mark ===
2012/11/29:01:57:56 Mark MARK-PC Launch
2012/11/29:01:58:13 Mark MARK-PC === Setup ended ===
2012/11/29:01:57:57 Mark MARK-PC === Setup started on MARK-PC by Mark ===
2012/11/29:01:57:57 Mark MARK-PC Launch
2012/11/29:01:58:05 Mark MARK-PC Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/11/29:01:58:07 Mark MARK-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/11/29:01:58:07 Mark MARK-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/11/29:01:58:12 Mark MARK-PC PageOpen LaunchDialog
2012/11/29:01:58:37 Mark MARK-PC PageOpen LicenseDialog
2012/11/29:01:59:04 Mark MARK-PC PageOpen ProductInfoDialog
2012/11/29:01:59:29 Mark MARK-PC PageOpen InventorFlavorSelectionDialog
2012/11/29:01:59:29 Mark MARK-PC Inventorui==DefaultLanguage: en-us
2012/11/29:01:59:29 Mark MARK-PC Inventorui==InstallName: INVENTOR
2012/11/29:01:59:29 Mark MARK-PC Inventorui==ProductName: Autodesk Inventor 2012
2012/11/29:01:59:29 Mark MARK-PC Inventorui==DisplayName: Autodesk® Inventor® 2012
2012/11/29:01:59:29 Mark MARK-PC Inventorui==DeploymentName:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==SetupTitle: Autodesk Inventor 2012
2012/11/29:01:59:29 Mark MARK-PC Inventorui==ConfigTransform:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==ExeParams:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/11/29:01:59:29 Mark MARK-PC Inventorui==SupportLink:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==InfotainmentLink:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==MsiFileName: inventor.msi
2012/11/29:01:59:29 Mark MARK-PC Inventorui==AdminImageConfigName: AdminImagex64
2012/11/29:01:59:29 Mark MARK-PC Inventorui==AdminImageRoot:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==GetBaseDeploymentName:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==DeploymentLocation:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2012/11/29:01:59:29 Mark MARK-PC Inventorui==InstallDeploymentShortcut:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==ModifyDeploymentShortcut:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==SetupLockType: 2
2012/11/29:01:59:29 Mark MARK-PC Inventorui==SetupNetworkType: 0
2012/11/29:01:59:29 Mark MARK-PC Inventorui==SystemLocale: 18441
2012/11/29:01:59:29 Mark MARK-PC Inventorui==EvalMsiFilePath: C:\Users\Mark\AppData\Local\Temp\_AIE488.tmp\SetupRes\eval.msi
2012/11/29:01:59:29 Mark MARK-PC Inventorui==EulaPath: C:\Users\Mark\AppData\Local\Temp\_AIE488.tmp\EULA
2012/11/29:01:59:29 Mark MARK-PC Inventorui==InstallLogPath: C:\Users\Mark\AppData\Local\Temp\Inventor2012Install.log
2012/11/29:01:59:29 Mark MARK-PC Inventorui==ConfigFile: C:\Users\Mark\AppData\Local\Temp\_AIE488.tmp\Setup.ini
2012/11/29:01:59:29 Mark MARK-PC Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:01:59:29 Mark MARK-PC Inventorui==NetworkLogPath:
2012/11/29:01:59:29 Mark MARK-PC Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:01:59:31 Mark MARK-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/11/29:01:59:31 Mark MARK-PC PageOpen ProductSelectionDialog2
2012/11/29:01:59:40 Mark MARK-PC PageOpen FullProgressDialog
2012/11/29:01:59:40 Mark MARK-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Mark\AppData\Local\Temp\vcredist_x86_2010.log
2012/11/29:01:59:42 Mark MARK-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/11/29:01:59:43 Mark MARK-PC PageOpen InstallCompleteDialog
2012/11/29:02:00:26 Mark MARK-PC === Setup ended ===
2012/11/29:02:11:08 Mark MARK-PC === Setup started on MARK-PC by Mark ===
2012/11/29:02:11:08 Mark MARK-PC Launch
2012/11/29:02:11:20 Mark MARK-PC === Setup ended ===
2012/11/29:02:11:15 Mark MARK-PC Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/11/29:02:11:18 Mark MARK-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/11/29:02:11:18 Mark MARK-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/11/29:02:11:20 Mark MARK-PC PageOpen LaunchDialog
2012/11/29:02:13:18 Mark MARK-PC PageOpen LicenseDialog
2012/11/29:02:13:30 Mark MARK-PC PageOpen ProductInfoDialog
2012/11/29:02:13:44 Mark MARK-PC PageOpen InventorFlavorSelectionDialog
2012/11/29:02:13:44 Mark MARK-PC Inventorui==DefaultLanguage: en-us
2012/11/29:02:13:44 Mark MARK-PC Inventorui==InstallName: INVENTOR
2012/11/29:02:13:44 Mark MARK-PC Inventorui==ProductName: Autodesk Inventor 2012
2012/11/29:02:13:44 Mark MARK-PC Inventorui==DisplayName: Autodesk® Inventor® 2012
2012/11/29:02:13:44 Mark MARK-PC Inventorui==DeploymentName:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==SetupTitle: Autodesk Inventor 2012
2012/11/29:02:13:44 Mark MARK-PC Inventorui==ConfigTransform:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==ExeParams:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/11/29:02:13:44 Mark MARK-PC Inventorui==SupportLink:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==InfotainmentLink:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==MsiFileName: inventor.msi
2012/11/29:02:13:44 Mark MARK-PC Inventorui==AdminImageConfigName: AdminImagex64
2012/11/29:02:13:44 Mark MARK-PC Inventorui==AdminImageRoot:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==GetBaseDeploymentName:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==DeploymentLocation:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2012/11/29:02:13:44 Mark MARK-PC Inventorui==InstallDeploymentShortcut:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==ModifyDeploymentShortcut:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==SetupLockType: 2
2012/11/29:02:13:44 Mark MARK-PC Inventorui==SetupNetworkType: 0
2012/11/29:02:13:44 Mark MARK-PC Inventorui==SystemLocale: 18441
2012/11/29:02:13:44 Mark MARK-PC Inventorui==EvalMsiFilePath: C:\Users\Mark\AppData\Local\Temp\_AIF818.tmp\SetupRes\eval.msi
2012/11/29:02:13:44 Mark MARK-PC Inventorui==EulaPath: C:\Users\Mark\AppData\Local\Temp\_AIF818.tmp\EULA
2012/11/29:02:13:44 Mark MARK-PC Inventorui==InstallLogPath: C:\Users\Mark\AppData\Local\Temp\Inventor2012Install.log
2012/11/29:02:13:44 Mark MARK-PC Inventorui==ConfigFile: C:\Users\Mark\AppData\Local\Temp\_AIF818.tmp\Setup.ini
2012/11/29:02:13:44 Mark MARK-PC Inventorui==SetupPath: D:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:02:13:44 Mark MARK-PC Inventorui==NetworkLogPath:
2012/11/29:02:13:44 Mark MARK-PC Inventorui==SourceRoot: D:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:02:13:45 Mark MARK-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/11/29:02:13:45 Mark MARK-PC PageOpen ProductSelectionDialog2
2012/11/29:02:13:53 Mark MARK-PC PageOpen FullProgressDialog
2012/11/29:02:13:53 Mark MARK-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): D:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Mark\AppData\Local\Temp\vcredist_x86_2010.log
2012/11/29:02:13:55 Mark MARK-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/11/29:02:13:56 Mark MARK-PC PageOpen InstallCompleteDialog
2012/11/29:02:14:27 Mark MARK-PC === Setup ended ===
2012/11/29:02:48:40 Mark MARK-PC === Setup started on MARK-PC by Mark ===
2012/11/29:02:48:40 Mark MARK-PC Launch
2012/11/29:02:50:55 Mark MARK-PC === Setup ended ===
2012/11/29:02:48:55 Mark MARK-PC === Setup started on MARK-PC by Mark ===
2012/11/29:02:48:55 Mark MARK-PC Launch
2012/11/29:02:49:21 Mark MARK-PC Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/11/29:02:49:26 Mark MARK-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/11/29:02:49:26 Mark MARK-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/11/29:02:49:35 Mark MARK-PC PageOpen LaunchDialog
2012/11/29:02:49:40 Mark MARK-PC Inventorui== Parameter: Prereq_8 SetupMode:7 InstallState:1 InstallAction:0 Message:
2012/11/29:02:49:40 Mark MARK-PC PageOpen LicenseDialog
2012/11/29:02:49:44 Mark MARK-PC PageOpen LaunchDialog
2012/11/29:02:50:29 Mark MARK-PC PageOpen LicenseDialog
2012/11/29:02:52:14 Mark MARK-PC PageOpen ProductInfoDialog
2012/11/29:02:52:30 Mark MARK-PC PageOpen InventorFlavorSelectionDialog
2012/11/29:02:52:30 Mark MARK-PC Inventorui==DefaultLanguage: en-us
2012/11/29:02:52:30 Mark MARK-PC Inventorui==InstallName: INVENTOR
2012/11/29:02:52:30 Mark MARK-PC Inventorui==ProductName: Autodesk Inventor 2012
2012/11/29:02:52:30 Mark MARK-PC Inventorui==DisplayName: Autodesk® Inventor® 2012
2012/11/29:02:52:30 Mark MARK-PC Inventorui==DeploymentName:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==SetupTitle: Autodesk Inventor 2012
2012/11/29:02:52:30 Mark MARK-PC Inventorui==ConfigTransform:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==ExeParams:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/11/29:02:52:30 Mark MARK-PC Inventorui==SupportLink:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==InfotainmentLink:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==MsiFileName: inventor.msi
2012/11/29:02:52:30 Mark MARK-PC Inventorui==AdminImageConfigName: AdminImagex64
2012/11/29:02:52:30 Mark MARK-PC Inventorui==AdminImageRoot:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==GetBaseDeploymentName:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==DeploymentLocation:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2012/11/29:02:52:30 Mark MARK-PC Inventorui==InstallDeploymentShortcut:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==ModifyDeploymentShortcut:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==SetupLockType: 2
2012/11/29:02:52:30 Mark MARK-PC Inventorui==SetupNetworkType: 0
2012/11/29:02:52:30 Mark MARK-PC Inventorui==SystemLocale: 18441
2012/11/29:02:52:30 Mark MARK-PC Inventorui==EvalMsiFilePath: C:\Users\Mark\AppData\Local\Temp\_AI226E.tmp\SetupRes\eval.msi
2012/11/29:02:52:30 Mark MARK-PC Inventorui==EulaPath: C:\Users\Mark\AppData\Local\Temp\_AI226E.tmp\EULA
2012/11/29:02:52:30 Mark MARK-PC Inventorui==InstallLogPath: C:\Users\Mark\AppData\Local\Temp\Inventor2012Install.log
2012/11/29:02:52:30 Mark MARK-PC Inventorui==ConfigFile: C:\Users\Mark\AppData\Local\Temp\_AI226E.tmp\Setup.ini
2012/11/29:02:52:30 Mark MARK-PC Inventorui==SetupPath: D:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:02:52:30 Mark MARK-PC Inventorui==NetworkLogPath:
2012/11/29:02:52:30 Mark MARK-PC Inventorui==SourceRoot: D:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:02:52:31 Mark MARK-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/11/29:02:52:31 Mark MARK-PC PageOpen ProductSelectionDialog2
2012/11/29:02:53:15 Mark MARK-PC PageOpen FullProgressDialog
2012/11/29:02:53:16 Mark MARK-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): D:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Mark\AppData\Local\Temp\vcredist_x86_2010.log
2012/11/29:02:53:19 Mark MARK-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/11/29:02:53:20 Mark MARK-PC PageOpen InstallCompleteDialog
2012/11/29:03:05:46 Mark MARK-PC === Setup ended ===
2012/11/29:03:06:00 Mark MARK-PC === Setup started on MARK-PC by Mark ===
2012/11/29:03:06:00 Mark MARK-PC Launch
2012/11/29:03:06:15 Mark MARK-PC === Setup ended ===
2012/11/29:03:06:01 Mark MARK-PC === Setup started on MARK-PC by Mark ===
2012/11/29:03:06:01 Mark MARK-PC Launch
2012/11/29:03:06:10 Mark MARK-PC Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/11/29:03:06:10 Mark MARK-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/11/29:03:06:10 Mark MARK-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/11/29:03:06:11 Mark MARK-PC PageOpen LaunchDialog
2012/11/29:03:06:26 Mark MARK-PC PageOpen LicenseDialog
2012/11/29:03:06:31 Mark MARK-PC PageOpen ProductInfoDialog
2012/11/29:03:06:44 Mark MARK-PC PageOpen InventorFlavorSelectionDialog
2012/11/29:03:06:44 Mark MARK-PC Inventorui==DefaultLanguage: en-us
2012/11/29:03:06:44 Mark MARK-PC Inventorui==InstallName: INVENTOR
2012/11/29:03:06:44 Mark MARK-PC Inventorui==ProductName: Autodesk Inventor 2012
2012/11/29:03:06:44 Mark MARK-PC Inventorui==DisplayName: Autodesk® Inventor® 2012
2012/11/29:03:06:44 Mark MARK-PC Inventorui==DeploymentName:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==SetupTitle: Autodesk Inventor 2012
2012/11/29:03:06:44 Mark MARK-PC Inventorui==ConfigTransform:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==ExeParams:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/11/29:03:06:44 Mark MARK-PC Inventorui==SupportLink:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==InfotainmentLink:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==MsiFileName: inventor.msi
2012/11/29:03:06:44 Mark MARK-PC Inventorui==AdminImageConfigName: AdminImagex64
2012/11/29:03:06:44 Mark MARK-PC Inventorui==AdminImageRoot:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==GetBaseDeploymentName:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==DeploymentLocation:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2012/11/29:03:06:44 Mark MARK-PC Inventorui==InstallDeploymentShortcut:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==ModifyDeploymentShortcut:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==SetupLockType: 2
2012/11/29:03:06:44 Mark MARK-PC Inventorui==SetupNetworkType: 0
2012/11/29:03:06:44 Mark MARK-PC Inventorui==SystemLocale: 18441
2012/11/29:03:06:44 Mark MARK-PC Inventorui==EvalMsiFilePath: C:\Users\Mark\AppData\Local\Temp\_AI1BAA.tmp\SetupRes\eval.msi
2012/11/29:03:06:44 Mark MARK-PC Inventorui==EulaPath: C:\Users\Mark\AppData\Local\Temp\_AI1BAA.tmp\EULA
2012/11/29:03:06:44 Mark MARK-PC Inventorui==InstallLogPath: C:\Users\Mark\AppData\Local\Temp\Inventor2012Install.log
2012/11/29:03:06:44 Mark MARK-PC Inventorui==ConfigFile: C:\Users\Mark\AppData\Local\Temp\_AI1BAA.tmp\Setup.ini
2012/11/29:03:06:44 Mark MARK-PC Inventorui==SetupPath: D:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:03:06:44 Mark MARK-PC Inventorui==NetworkLogPath:
2012/11/29:03:06:44 Mark MARK-PC Inventorui==SourceRoot: D:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/11/29:03:06:46 Mark MARK-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/11/29:03:06:46 Mark MARK-PC PageOpen ProductSelectionDialog2
2012/11/29:03:07:00 Mark MARK-PC PageOpen FullProgressDialog
2012/11/29:03:07:00 Mark MARK-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): D:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Mark\AppData\Local\Temp\vcredist_x86_2010.log
2012/11/29:03:07:02 Mark MARK-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
