• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    ***Guru
    TravisNave
    Re: Autodesk Installation Problems
    01-30-2012 07:45 AM in reply to: hshdavidson
    hshdavidson,
    Sorry for the delay on this over the weekend.  Attached is a modified setup.ini file (just remove the .txt) that has the prerequisite checks for your Revit on the Visual C++ removed.  I have had success doing this before, so it may very well work for you, or you might end up with a different problem altogether.  It is at least worth a shot.  Definitely make sure you have the actual prerequisites installed, obviously, so that the product will work as expected.  Let me know if you still have problems.  And thank you for being polite and professional.  :smileywink:
    Good Luck!
    Note:  I went into the file and removed all instances of VCREDIST on a search, including references to the 3rd party installers at the bottom.
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    hshdavidson
    02-02-2012 11:47 AM in reply to: TravisNave
    Boy, is this really getting to be a pain in the butt.
    I am having trouble downloading the attachment you sent.  On the discussion-group page the attachment is actually a link.  When I click on it I get a new page filled with text which I presume I am supposed to copy and paste into a .txt file.  But on the webpage  there are these � characters that appear between each letter in the text. I paste into Notepad and I get a little box character there.
    What is going on?  How do I correct this?
    scott
    ***Guru
    TravisNave
    02-02-2012 11:55 AM in reply to: hshdavidson
    Right-click the link of the file and Save target as...  That should save it as the file.  Then just remove the .txt extension leaving just setup.ini.  Replace the one you have with this one and start the installer.  Good Luck!
    Active Member
    hshdavidson
    02-03-2012 08:57 AM in reply to: TravisNave
    I tried the right-click but no "save target" option there, only "Save Link as...". But I was able to edit teh characters out with Wordpad, replaced the original -.ini isth it and ran it.  Failed like so:
    midway through installation, and at various times in teh process:
    .netframework2.0(x64):  "Error: .netframe versionincompatible with previous installed one"
    setup.exe: " netframe encountered problems..." Failed
    seupverifier.exe - DLL Initialization failed"
    Revit 2012:  1309 Error.  file c:.../../AutoDesk Design review 2012.name.png.  make sure you have this file."  Ignore
        Again: 1309 Error.  .../DesignRev-install.png.  Ignore
    Netframe 3.5 SP1 Setup:  I chose "repair"  : "restoring to original state"
    Revit 2012:  1309 Error.  file c:.../../ArchVis_Stills_...Spirea.rpc.png.  make sure you have this file."   Ignore
    Then Revit continues setup until the Installer crashes.
    Why is this happening to me?  Its really getting frustrating, not to mention time-consuming.
    Thanks for your help.
    Scott
    ***Guru
    TravisNave
    02-03-2012 11:12 AM in reply to: bone3
    Are you using Internet Explorer? Make it your default browser. If you have .NET Framework issues, I provide a cleanup tool for that too in my signature. Hang in there...
    Member
    wlaubner
    02-04-2012 07:15 AM in reply to: bone3
    After 8 attempts and taking acad to a computer repair ship; he finally had to reformat mat my disk to get it to load. It only cost me a mere $175 to get it done........where do I send the bill to..?
    ***Guru
    TravisNave
    02-04-2012 09:51 AM in reply to: bone3
    Formatting and reinstalling can be done for free. The fact of the matter is that the installation problems are due to prerequisite files, not the Autodesk software. In my opinion, you overpaid for service that wasn't necessary.
    Member
    wlaubner
    02-04-2012 12:14 PM in reply to: bone3
    It's because auto desk was untimely or completely lacking in a fix. Rather they said contact a local retailer. That's not a fix and this guy spent a lot of time attempting installation over and over again. The lack of support SUCKS.
    ***Guru
    TravisNave
    02-04-2012 01:11 PM in reply to: bone3
    Support is handled primarily thru the reseller partner channel. If you want better support, buy from a value-added reseller and not by clicking buy now on a website like CDW. This is a peer-based forum. We choose to help out the community for the greater good. Glad you are up and running.
    Active Member
    hshdavidson
    02-07-2012 02:28 PM in reply to: TravisNave
    Finally got back to trying to install Revit on my WinXP64 machine.  I used IE to downloaded the setup.txt file you attached,  placed it, as a .ini file, in the installer folder and let her rip.  Same stuff.  Several  missing .png file messages came up during the installatoin but it kept on installing.  Could my download of Revit be corrupted?  red Xs next to all three apps.
     I'm attaching the Installation Log file.
    thanks for your help.
