Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Autodesk Installati on Problems
- Highlight
- Email to a Friend
- Report Inappropriate Content
I'm a student who decided to use the education program to make some animations. However I cannot do that. First I decided to try out 3Ds Max. Everything went ok till the installation itself. After a couple of tries I gave up and tried to install 3D Maya. Same problem. I meet the requirements. I have tried a couple of times following installation tutorials (deactivating antivirus program, closing other running programs, etc.) but they did not help. Burried myself in every possible article about such problems but couldn't find anything. I can't see what kind of error this is because when I try to check the logfile nothing happens. Here is everything I get when I try installing them (not only 3Ds Max but Maya, too):
If you don't know what the problem is, then at least tell me how to check the logfile, please.
Re: Autodesk Installati on Problems
- Highlight
- Email to a Friend
Anyone?
- Highlight
- Email to a Friend
Attach the log file, as it will include the reason for failure. If you cannot get to it from the GUI link in the failed install, then you can get to it manually by typing %TEMP% in your Start > Run box. Sort by date. The installation log file should appear near the top if it was the last thing you did.
My Top Contributions to the Discussion Groups:
FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files |
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Autodesk Installati on Problems
- Highlight
- Email to a Friend
I have a similar problem. I'm a student trying to install Revit Arch 2012 in WinXP64. I successfully installed AutoCAD 2012 first, then revit. The installer gets all teh way throuhg then tells me that install of all apps hvae failed. I tried (as per Autodesk site instructions: http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
2012/1/27:13:38:14 Administrator EVOL === Setup started on EVOL by Administrator ===
2012/1/27:13:38:14 Administrator EVOL Launch
2012/1/27:13:39:39 Administrator EVOL === Setup ended ===
2012/1/27:13:38:18 Administrator EVOL === Setup started on EVOL by Administrator ===
2012/1/27:13:38:18 Administrator EVOL Launch
2012/1/27:13:39:39 Administrator EVOL PageOpen LaunchDialog
2012/1/27:13:39:51 Administrator EVOL PageOpen LicenseDialog
2012/1/27:13:40:31 Administrator EVOL PageOpen ProductInfoDialog
2012/1/27:13:41:06 Administrator EVOL PageOpen ProductSelectionDialog2
2012/1/27:13:41:15 Administrator EVOL PageOpen FullProgressDialog
2012/1/27:13:41:15 Administrator EVOL Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Documents and Settings\Administrator\My Documents\Downloads\Autodesk_Revit_Architecture_20
2012/1/27:13:41:18 Administrator EVOL Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/1/27:13:41:18 Administrator EVOL PageOpen InstallCompleteDialog
2012/1/27:13:41:33 Administrator EVOL === Setup ended ===
Looks like installation of Visual C++ 2010 Redistributable failed. shall I try installing this first seperately?\]
scott
- Highlight
- Email to a Friend
Chances are it is failing because a newer version is already installed. Rather you should uninstall the Visual C++ 2010 and then let the installer reinstall it on its own.
- Highlight
- Email to a Friend
Thanks for the advise. So here is the logfile. To make it short: Errors 1622 and 1619 occur. What should I do?
- Highlight
- Email to a Friend
Consider copying the entire contents of your media to a folder on your local hard drive and install from there. Make sure that you have local admin rights and that your anti-virus is disabled.
- Highlight
- Email to a Friend
What do you mean by "contents of your media"?
- Highlight
- Email to a Friend
If this is a download, than it's already done for you. I had just noticed you were installing from F:\ and I wanted to make sure it was not a disc or USB media.
- Highlight
- Email to a Friend
So what do you suggest then?
